Change language RT3
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
bekinelis
Re: Change language RT3
Unread post by bekinelis »
Thanks you so much! Amazing
jekitoss
Unread post by jekitoss »
Hello, I have a 2005 Peugeot 407 wagon - software version is 6.63. I need to change the language from German to English and I will be very grateful if you can help me too! Thank you in advance
Reason: Image fixed
x 6960
@jekitoss: Check your Private Messages
Sander B
Unread post by Sander B »
Hi, I Have a 2006 citroen c6 and the same language issues as the other members. Maybe you can help me with the most recent software version so i can change the language? Lot of thanks in foreward!
Greetings from the Netherlands, Sander
Software version 6.62
x 6960
Hi @ Sander B, check your Private Messages.
Cholera
Unread post by Cholera »
Hello,
I need it too (eng):
Thx
cole307
New User
Unread post by cole307 »
Hi, i have Peugeot 307sw RT3 navigation, update is 5.5 can someone send me cd download so i can burn and change languation, also how do i use map, thanks
Cholera
Cholera wrote: 23 Dec 2023, 11:13 Hello,
Thx
Hello,
Any help please @GiveMeABreak ?
Thank you
Mickey1987
Unread post by Mickey1987 »
Hello! Can you help me change the language on my 2003 peugeot 307cc radio? Thanks
x 6960
@ Mickey1987, check your PM, you need a different firmware, details in the PM.
Mickey1987
Thank you!
Mickey1987
Hello! Change of language was successful. An error message is displayed and an LED flashes, can this be removed? Assistance call, Service Downgraded
x 6960
That will be because the the SIM card is missing, has expired or has no credit. This is normal behaviour and means the system cannot connect to emergency services in the even of a crash and airbag deployment.
It can't be deactivated as this is normal behaviour.
Mickey1987
LanciaPhedra2004
Unread post by LanciaPhedra2004 »
Hi forum RT3 users. I have same problem here in lancia phedra 2004 with rt3 v5.5D on board. Its software is in Italian and I would like to change it to English. I also have some cd with firmware v5.5 but I am unable to use it since after inserting cd (even music one) it is not read. Actually, when pressing source button nothing happens, and only radio mode is available. Do you have any workarounds to propose?
Thanks in advance for help.
