I have just bought my second Xsara Picasso but comes with a few faults.
It's an 06 model 1.6hdi. the faults point to a new lighting trafficator sw.
When indicating left with headlight on ind flashes for 3 flashes and then stops.
Also noticed that foglights are not coming on which will be an MOT fail .
Obviously I can replace the switch fiddly but doable .
Various bulbs out on dash headlight mainly but headlights do work.
Previous owner said cigar lighter has a fault causing fuse to blow so will have to check that along with a weird rear screen demister which lights up when it wants.
As said elsewhere servicebox now wants money but have sedre on an older laptop.
Must say though car drives nice.
Derekg
Xsara Picasso 06 lighting switch.
Derekg
Re: Xsara Picasso 06 lighting switch.
A follow up to my last post.
I have changed the indicator arm in the com2000 unit and lights inc fog front and rear now work.
Indicators now flash more than 3 times.
It would appear that the climate control (manual) version does not want to play.
OnlineRp0thejester
- x 1066
I'm now subscribing to this as mine is an 06 but a C8, so should be identical in electronics. Was there a short somewhere with the wires? And does your service box have the right software to speak to the evil b*tch your trying to fix?
Champion of Where's CitroJim
- x 1056
Servicebox/Sedre is for repair manuals/parts diagrams/wiring diagrams. The old backup copy should be fine for a 2006 Picasso.
