When I do a battery off/on does the window have to stay open?
I want to disconnect the battery, leave overnight and complete the radio install the next day. With this weather it's not possible.
BSI reset/Battery disconnection/ reconnection query
mitsub
- x 1056
Re: BSI reset/Battery disconnection/ reconnection query
There is no reason that the window would need to stay open to disconnect/reconnect the battery
- x 5657
It is so that you can reach in and turn the lights on and off etc. according to the official procedure.
I had to leave my car at work when the battery died and take it home to charge it up which made a mess of that procedure, no opportunity to open the window or to leave it open in works car park.
The reason is partly that opening the door activates the suspension ECU which can upset the reboot procedure.
I circumvented this by sitting in the car and having a mate reconnect the battery and running through the procedure with the window closed but without having to open the door.
All went well but I have no guarantees to offer.
- x 1056
The official procedure tells you to turn on the lights after re connecting the battery??myglaren wrote: 20 Dec 2023, 21:31 It is so that you can reach in and turn the lights on and off etc. according to the official procedure.
If it does i have never done this & have disconnected & reconnected literally hundreds of PSA batteries without any issues.
If you feel that you need to switch the lights on before opening a door just flick the latch over with a screwdriver before re connecting the battery.
- x 6955
Leaving the window open is really just for emergency access in case you need to get in or out of the vehicle, where there may be an issue with locking for example.mitsub wrote: 20 Dec 2023, 17:44 When I do a battery off/on does the window have to stay open?
I think the sidelights on was from an older procedure many moons ago, but I've left it in there. It's not required though. What is important is the timings and that the doors and boot are closed to ensure the vehicle networks will go to sleep and they won't do this with a door open.
mitsub
thank you all for your replies, it makes it easier for me.
