x 8378
Excellent work Matt :)
c16rkc
x 104
Unread post by c16rkc »
Pleased the universal puller worked; wish I'd bought that instead of the special one now :lol:
x 8100
I shouldn't worry Chris, I had the universal puller when I was 17 but I still had to go to 30+ discos before it worked!! :-D
x 8378
mickthemaverick wrote: 05 Dec 2023, 13:50 I shouldn't worry Chris, I had the universal puller when I was 17 but I still had to go to 30+ discos before it worked!! :-D
:lol: :lol:
x 2341
Unread post by MattBLancs »
I'm not sure clanking this thing round the local disco would have done me any good!
Similar to what I bought
:rofl2:
x 2341
I tried it previously and all it managed to do was bend the threaded rod a touch (think was lower engine mount I was attempting to fit)
Fortunately a couple the silver pieces of the sizes I needed survived the "pound the living snot out of them with a big hammer" technique I had to deploy instead!
x 2341
Good news: C5 MOT passed, no advisories :)
Bad news: Coupe very much did not
x 8100
Well done and oooppss!!! :-D
x 2341
Brake lights do take a long time to go off when pedal released. Pedal is slower to rise (than the other Lucas caliper equipped Coupe) but I'd put this down to the four pot Brembos calipers. As to the brake light remaining on as a result, not something I'd noticed (from the driver's seat :-D bit hard to see, no!)
Not sure about this rear sill rust, I did not spot anything, but will soon find out.
x 2341
mickthemaverick wrote: 05 Dec 2023, 17:26 Well done and oooppss!!! :-D
Err, yes, precisely! :)
x 8378
Mick has said it all most eloquently Matt and I can only agree :)
I'm sure the Coupe will be good and in rude health very soon... At least you know precisely what's needed.
On the brake issue, check the flexi hoses have not collapsed internally and are acting like little accumulators/one-way valves - that could well account for the 'slow' pedal...
x 2341
CitroJim wrote: 05 Dec 2023, 17:47 Mick has said it all most eloquently Matt and I can only agree :)
Thanks Jim. I've got new front Flexi hoses "in stock" as were advisory last year (not mentioned this time) I'll put a request on the parts number thread for the bleed nipples front and rear - I always put new on first time I've some bleeding to do on a car (as usually find some "rusty stumps" waiting for me at each corner!) Not sure if the Brembos are different to the Lucas calipers (M10x1.0 from memory) rears are M7x1.0.
x 8378
Yes, M7x1 is the standard nipple size Matt... I've a feeling the Brembos will be these... Must say I've not come across an M10 nipple from memory but have seen M8 and M6 ones...
M8 can be good when you need to drill out and retap an M7 and I've used M6 ones to make up little adaptors to retrieve hopelessly damaged M7 nipple threads in alloy calipers...
x 2341
Loving that bit of resourcefulness there Jim! (And excuse for a play with the lathe too :) )
Am pretty sure the other Coupe was M10x1.0 one end, M7x1.0 on the other.
In fact, looking back in time in my eBay purchase history, it seems I bought all these:
Stocking up! (Forgotten id bought these!)
Just need to recall where I might have neatly stored them in the garage....
x 2341
The above pre dates buying the HDi Coupe, so would be aimed at Coupe or C5 use.
