307 clutch pedal vibration..?
Slobo2712
Unread post by Slobo2712 »
Hello everyone,I have this issue for about 3-4 months.Clucth pedal is vibrating when it's pressed at half.You can her this vibration only inside car,not on engine.There is no vibration when switching off car or anything else,car is beheving like normal.Tnx in advance
x 8140
Re: 307 clutch pedal vibration..?
I know nothing about Peugeot clutches but that sound to me is the sound of a dry release bearing. If the noise goes away as you press the clutch right in then that would be my guess!! :)
Slobo2712
Vibration stops when you move this cylinder by hand..?
x 8418
Check your bellhousing (engine to gearbox) bolts are tight...
x 8140
You shouldn't be able to move that by hand I don't think. Check its mounting bolts and Jim advises checking the bellhousing bolts too. :)
Slobo2712
Not entire cylinder,I can move by hand just this part behind rubber.
x 8418
That's looking very much like a failing release bearing or a failing clutch diaphragm spring...
x 8140
Does the clutch operating arm move with the cylinder rod or just the rod?
Slobo2712
mickthemaverick wrote: 03 Dec 2023, 07:48 Does the clutch operating arm move with the cylinder rod or just the rod?
Yes,everything is working as it should,no car vibrations shaking,nothing at all..
x 8140
I meant when you move it by hand?
