Hi! would it be possible to get any instructions and part number to replace the blower motor in our ds3? Thank you
DS3 blower motor replacement
- x 6947
Re: DS3 blower motor replacement
Blower Motor or Blower Motor Control Module?
Here's both in case.
(1) Blower Motor, part: 6441CS, £473.08
(5) Heater Motor Control Module, part: 6441S7, £201.25
dylan26__
- x 22
6441cs , the motor itself. Is there any directions to replace it? Thank you
- x 6947
Info on replacing this is limited
Info is for left hand drive, so should be easier on a RHD from the passenger compartment, but essentially after you have removed the passenger right side trim panel in the footwell:
Remove:
Make sure you disconnect the battery following the BSI Reset / Battery Disconnect / Reconnect Procedure
Remove:
- The (10) bolt
- The heater matrix pipes retaining plate (11)
- The air blower (Turn a quarter of a turn)
dylan26__
- x 22
Cheers, i'm sure i'll figure it out.GiveMeABreak wrote: 27 Nov 2023, 10:23 Info on replacing this is limited
Remove:You may need to remove the air ducting if in the way, but there's nothing else on this I have.
- The (10) bolt
dylan26__
- x 22
Can't even get the side panels off! What's the knack here
- x 6947
Undo the bold at (3) then unclip the trim at (a) to remove the panel (4). This is LHD, but RHD will be the same.
dylan26__
- x 22
i got that off but it seems the glovebox is what needs to come out as the motor is alot higher. any instructions for the glovebox?
- x 6947
Check back here in 20 minutes for a link on what I have.
Ok, so here is the info on Glove Box Lid and GLove Box, which may be what you need to get access to the other part:
DS3 3 Door GloveBox Lid / GloveBox Removal - Refitting
dylan26__
- x 22
Thank you as always marc. I really do appreciate all you do for the forum. I'll try make another donation in January for you cause i really do get moneys worth.GiveMeABreak wrote: 01 Dec 2023, 15:10 Check back here in 20 minutes for a link on what I have.
