Citroen c5x7 squeaky noises while turning left
508c5
x 4
Unread post by 508c5 »
Citroen c5x7 with hydro-pneumatic suspension.
When turning the steering wheel left (even slightly) while the car is moving, a continuous squweel sound appears (similar to what a cricket makes...) , it stops when going back straight (when turning right it doesn't happen as well).
The serpentine belt is new, the pulleys seem ok (not loosened), the LDS is fresh, it happens at evry hight as well, Wishbones seem healthy
I am out of ideas.
Any idea will be welcomed.
x 1072
Re: Citroen c5x7 squeaky noises while turning left
Unread post by Rp0thejester »
First of all power steering fluid, secondly Anti roll link rod bar.
508c5
x 4
Rp0thejester wrote: 19 Nov 2023, 18:47 First of all power steering fluid, secondly Anti roll link rod bar.
As mentioned, LDS (power steering fluid) is fresh.
I doubt it is the link, doesn't sound like a metallic friction sound.
x 1072
I know but I've had the same thing, if it's only on the left then it's worth a check
x 6945
@508c5: Be advised that there is no belt linked to the power steering on this model, it has the electro pump, so operated directly from the battery.
The only thing I can suggest is one of the power steering pipes at the steering rack near the pinion. Check to see if there is any fluid leaking from this area from under the car (but don't get underneath without supporting the vehicle independently as suspension can drop suddenly and crush) and see of there is a puddle on the ground or a slow leak from the high pressure pipe.
(1) is the High pressure pipe, (2) is the low pressure pipe.
If it was the accessories belt, I would expect this to squeal a little regardless of turning the steering wheel.
508c5
x 4
Agreed and i know the steering pump isn't independent of the serpentine belt. No evident leak.
I thought maybe the link in the following link might be cause
https://www.ebay.com/itm/256222329080?h ... BMuo7Fivti
x 6945
Can't see how as this is just the body height link rod, so if it was squeaking it would be doing it all the time the car rises and lowers when driving. It's independent of the steering.
508c5
x 4
In my previous quote isn't was supposed to be is.
The fact that it happens only when steering left is most confusing with regard to the pipes you suggested as well - same pressure (i would think..) is applied when turning left, as well as right, so why would they squeal only in one direction? Is this prone to politics as well.. :lol: ?
Estately
x 22
Unread post by Estately »
Have you considered that this noise could be coming from one of the discs, caused by a small piece of road grit getting lodged somewhere.
A bit of detective work with one then the other window open to indicate which side of the car the noise is coming from.
Does the noise happen in reverse?
Can you hear the noise under various braking conditions?
Maybe get (left then right) wheels off the ground and rotate them by hand to listen for an odd sound. REMEMBER TO SET THE RIDE HEIGHT TO MAXIMUM and
do not allow yourself to get anywhere under the car.
Hope that helps.
Andy.
If it can happen it will.
Clogzz
x 40
Unread post by Clogzz »
I've had something like that, on left turn only.
It was low LDS level.
508c5
x 4
Estately wrote: 21 Nov 2023, 23:14 Have you considered that this noise could be coming from one of the discs, caused by a small piece of road grit getting lodged somewhere.
Hope that helps.
Andy.
Thx, checked brakes already, all seems to be all right
508c5
x 4
Clogzz wrote: 22 Nov 2023, 11:48 I've had something like that, on left turn only.
LDS level is correct
508c5
x 4
GiveMeABreak wrote: 19 Nov 2023, 21:33 @508c5: Be advised that there is no belt linked to the power steering on this model, it has the electro pump, so operated directly from the battery.
Hi
Do you have the part number for pipe number 3 in the sketch?
x 6945
It was 4014NT, but no longer available from Citroen.
508c5
x 4
GiveMeABreak wrote: 31 Dec 2023, 11:31 It was 4014NT, but no longer available from Citroen.
thanks, that's NO.1 i think...anyway...i found no. 3 (4012p3) but also not available (at least not at reasonable prices) - do you know the inner diameter (ID) size? is it 13mm?
THANKS
