- x 6950
Ok, so,
(1) Soundproofing Under Engine & Gearbox
There are 2 possibilities under this part:
Part: 7013EC, Large, £381.94
Part: 8108ER, Long 1250 £429.22
I can't tell you which you have, as it specifies both are possibilities.
(70) Flanged Nut 6X100, part: 6936C9, £1.20
(71) Cage Screw Diam 6X100-20, part: 698403, £2.32
(72) Screw with Washer, Diam 6X100-20, part: 692395, £1.48
(74) Cage Nut 6X100, part: 6941C0, £3.29
NorfolkVroom
- x 5
Huskyxantia
- x 928
VF3**************[VIN obfuscated, can be read by forum staff] part number required for the rear shocks . Thank you .
Husky.
- x 6950
(1) OEM Rear Damper replacement part: 9811614580, £105.90 each
(1) Cheaper Alternative, Part: 1623318080 (Damper Only), £47.95 each
Billsy
- x 9
VR3**************[VIN obfuscated, can be read by forum staff]
2021 208 Allure
Hi I have a bit of a project kicking off
Can I please have the part numbers and prices for the following:
Front left wing, headlight, DRL & wheel arch liner
Bonnet
Front bumper (just the main plastic part)
Items 2, 4, 8 & 10 in the picture.
For item 10 I'm hoping I can get the circled part only. However it's spot welded on so I doubt it?
Also the boot floor (carpeted removable)
2021 208 Allure
Bonnet
- x 6950
First off, there's an after-sales campaign outstanding on this vehicle concerning:
"KNK - Battery protector
The operation involves adding the protector of the 12V battery positive terminal."
So when you get the vehicle back up, I'd get it booked in, it's a no-cost repair.
So your diagram is out of date as there are some changes to parts:
Wing 1) Front Left Wing, part: 9823208480, £224.41
2) Front Wing Inner Frame (Left), part: 1646180980, £339.82
4) Front Wing Support (Left), part: 9828273680, £60.95
8) Front Wing Support (Left), part: 9827381780, £61.78
10) Front Wheel Arch (Left), part: 1638952180, £253.48
15) Wheel Housing Mudguard (Left), part: 9823309180, £152.46
Boot
Not sure which parts you mean for the boot floor. You'll have to let me know the item numbers from the diagram below:
DRL 1) Front Left Hand Lamp, part: 9824241480, £274.90
Headlamp 1) Complete Headlamp (Left), part: 9833036280, £679.43
40) Driver Kit, part: 1656251280, £246.26
50) Headlamp Repair Bracket Kit, part: 1656169580, £73.13
Bonnet 1) Bonnet, part: 9827576880, £516.19
Bumper 1) Front Bumper, part: 164982701T, £580.12
Boot
Billsy
- x 9
Thanks very much Marc and thanks for the additional info about the battery protector.
The part for the boot is just the carpeted removable thingy, mine is MIA
Thanks again
Thanks again
- x 6950
No worries, ok so:
(1) Boot Carpet, part: 98247916ZD, £254.44
(2) Boot Mat Support (in case that's missing too), part: 9820800880, £35.04
Note your vehicle doesn't have item (5) as shown.
dave101ua
Hello !
hope you are well
Could you please give part numbers for break pads both front and rear
here is VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
hope you are well
Thanks in advance
- x 6950
Front Pads
(4) Front Brake Pad Kit, part: 1647863680, £149.98
Rear Pads (2)
OEM Original Pad Kit, part: 1647860380, £108.74
Cheaper Citroen Kit, part: 1619791280, £49.14
Rear Pads (2)
- x 1952
A quickie
6 speed ML6 gearbox on my C5 X7, part number for the washer to go on the gearbox drain plug please. Price and unit of issue as well please.
- x 6950
(12) Plug Seal (Diam 16X22-2), part: 031038, £0.85 ea.
Dunkah
- x 11
Hi Marc, can I have a diagram and part numbers for the front body height sensor please
C5 tourer 2008
Vin VF7**************[VIN obfuscated, can be read by forum staff]
C5 tourer 2008
- x 6950
(1) Front Body Height Sensor, part: 5273J4, £86.02
Dunkah
- x 11
Excellent, thank you Marc
