x 6955
Ok, so,
(1) Soundproofing Under Engine & Gearbox
There are 2 possibilities under this part:
Part: 7013EC, Large, £381.94
Part: 8108ER, Long 1250 £429.22
I can't tell you which you have, as it specifies both are possibilities.
(70) Flanged Nut 6X100, part: 6936C9, £1.20
(71) Cage Screw Diam 6X100-20, part: 698403, £2.32
(72) Screw with Washer, Diam 6X100-20, part: 692395, £1.48
(74) Cage Nut 6X100, part: 6941C0, £3.29
NorfolkVroom
x 5
Unread post by NorfolkVroom »
Awesome, cheers.
Huskyxantia
x 879
Unread post by Huskyxantia »
VF3**************[VIN obfuscated, can be read by forum staff] part number required for the rear shocks . Thank you .
:-D
x 6955
(1) OEM Rear Damper replacement part: 9811614580, £105.90 each
(1) Cheaper Alternative, Part: 1623318080 (Damper Only), £47.95 each
Billsy
x 9
Unread post by Billsy »
VR3**************[VIN obfuscated, can be read by forum staff]
2021 208 Allure
Hi I have a bit of a project kicking off :shock: Can I please have the part numbers and prices for the following:
Front left wing, headlight, DRL & wheel arch liner
Bonnet
Front bumper (just the main plastic part)
Items 2, 4, 8 & 10 in the picture.
For item 10 I'm hoping I can get the circled part only. However it's spot welded on so I doubt it?
Also the boot floor (carpeted removable)
x 6955
First off, there's an after-sales campaign outstanding on this vehicle concerning:
"KNK - Battery protector
The operation involves adding the protector of the 12V battery positive terminal."
So when you get the vehicle back up, I'd get it booked in, it's a no-cost repair.
So your diagram is out of date as there are some changes to parts:
Wing
1) Front Left Wing, part: 9823208480, £224.41
2) Front Wing Inner Frame (Left), part: 1646180980, £339.82
4) Front Wing Support (Left), part: 9828273680, £60.95
8) Front Wing Support (Left), part: 9827381780, £61.78
10) Front Wheel Arch (Left), part: 1638952180, £253.48
15) Wheel Housing Mudguard (Left), part: 9823309180, £152.46
Boot
Not sure which parts you mean for the boot floor. You'll have to let me know the item numbers from the diagram below:
DRL
1) Front Left Hand Lamp, part: 9824241480, £274.90
Headlamp
1) Complete Headlamp (Left), part: 9833036280, £679.43
40) Driver Kit, part: 1656251280, £246.26
50) Headlamp Repair Bracket Kit, part: 1656169580, £73.13
Bonnet
1) Bonnet, part: 9827576880, £516.19
Bumper
1) Front Bumper, part: 164982701T, £580.12
Billsy
x 9
Thanks very much Marc and thanks for the additional info about the battery protector.
The part for the boot is just the carpeted removable thingy, mine is MIA
Thanks again
x 6955
No worries, ok so:
(1) Boot Carpet, part: 98247916ZD, £254.44
(2) Boot Mat Support (in case that's missing too), part: 9820800880, £35.04
Note your vehicle doesn't have item (5) as shown.
dave101ua
Unread post by dave101ua »
Hello !
hope you are well
Could you please give part numbers for break pads both front and rear
here is VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
x 6955
Front Pads
(4) Front Brake Pad Kit, part: 1647863680, £149.98
Rear Pads
(2)
OEM Original Pad Kit, part: 1647860380, £108.74
Cheaper Citroen Kit, part: 1619791280, £49.14
x 1930
A quickie
6 speed ML6 gearbox on my C5 X7, part number for the washer to go on the gearbox drain plug please. Price and unit of issue as well please.
x 6955
(12) Plug Seal (Diam 16X22-2), part: 031038, £0.85 ea.
Dunkah
x 11
Unread post by Dunkah »
Hi Marc, can I have a diagram and part numbers for the front body height sensor please
C5 tourer 2008
Vin VF7**************[VIN obfuscated, can be read by forum staff]
x 6955
(1) Front Body Height Sensor, part: 5273J4, £86.02
Dunkah
x 11
Excellent, thank you Marc
