And I have two more codes but I don’t think are related to this situation: U1218 and U1213. Please help me find a solution
Automatic Citroen C5 x7 Hydractive 2.0HDI 163hp RHH throttle pedal
ThomasH
Hello, greetings from Romania, I have a problem with my c5, when I turn the car on, the “check engine” light comes on . When I try to accelerate it won’t let me go past 3000 rpm. I have the following fault codes: P2132 and P2134.
- x 6954
Re: Automatic Citroen C5 x7 Hydractive 2.0HDI 163hp RHH throttle pedal
Here is the fault code data. Looks like the accelerator pedal may be the issue.
| Fault Code: | P2132 |
| Description of Fault: | Hard point switch on the accelerator pedal: Short circuit to earth. Voltage greater than 4,96 V. The fault immediately appears. |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P2134 |
| Description of Fault: | Hard point switch on the accelerator pedal : The voltage is jammed between "exceeded" and "not exceeded". Voltage less than 0,1 V or greater than 4,695 V. The fault immediately appears. |
| Symptoms: |
| Suspect Areas: |
