Roger take and post a picture of the wires and plug going to the air dryer i will try to dig out some old pictures of mine, from memory they were easy to see the difference in them.
Also look for posts by Clogzz i have to admit everything i know has been copied and added to with a bit of my experience
Colin
Xantia A/C
Rhothgar
- (Donor 2026)
- x 221
Re: Xantia A/C
Here you go, Colin.admiral51 wrote: 24 Oct 2023, 19:55 Roger take and post a picture of the wires and plug going to the air dryer i will try to dig out some old pictures of mine, from memory they were easy to see the difference in them.
Colin
Exactly as I said:-
- x 1443
Re: Xantia A/C
I think that you can see the wire numbers just peeking out of the sleeve.
Rhothgar
- (Donor 2026)
- x 221
Re: Xantia A/C
Not with my eyesight.xantia_v6 wrote: 25 Oct 2023, 16:29 I think that you can see the wire numbers just peeking out of the sleeve.
I know what the wire numbers are anyway but then again I am fairly sure that the colours do not match the official manual which is more than irritating. What's the point of them if they contain inaccurate information?
- x 1443
Re: Xantia A/C
Colours are irrelevant on Xantia wiring, only the wire numbers matter.
Rhothgar
- (Donor 2026)
- x 221
Re: Xantia A/C
That's what a mate said about French cars in general.xantia_v6 wrote: 25 Oct 2023, 17:14 Colours are irrelevant on Xantia wiring, only the wire numbers matter.
I didn't believe him. Why do Citroen put colours in their manuals if not relevant, do you know?
Most of the time they are right but sometimes they are way off.
- x 8335
Re: Xantia A/C
Yes, because they're FrenchRhothgar wrote: 25 Oct 2023, 17:17That's what a mate said about French cars in general.xantia_v6 wrote: 25 Oct 2023, 17:14 Colours are irrelevant on Xantia wiring, only the wire numbers matter.
Rhothgar
- (Donor 2026)
- x 221
Re: Xantia A/C
Les intendants du bar!CitroJim wrote: 25 Oct 2023, 17:20Yes, because they're FrenchRhothgar wrote: 25 Oct 2023, 17:17That's what a mate said about French cars in general.xantia_v6 wrote: 25 Oct 2023, 17:14 Colours are irrelevant on Xantia wiring, only the wire numbers matter.
Most of the time they are right but sometimes they are way off.![]()
admiral51
- (Donor 2026)
- x 391
Re: Xantia A/C
Hi Roger
Have a look at This Thread
2nd or 3rd post says about pins 1+2 need to be bridged to engage the clutch on the compressor
Colin
Colin
