Xantia A/C
Post your Cit/Peu/Ren air conditioning queries or advice.
admiral51
(Donor 2026)
x 391
Re: Xantia A/C
Unread post by admiral51 »
Roger take and post a picture of the wires and plug going to the air dryer i will try to dig out some old pictures of mine, from memory they were easy to see the difference in them.
Also look for posts by Clogzz i have to admit everything i know has been copied and added to with a bit of my experience
Colin
Rhothgar
(Donor 2026)
x 221
Re: Xantia A/C
Unread post by Rhothgar »
admiral51 wrote: 24 Oct 2023, 19:55 Roger take and post a picture of the wires and plug going to the air dryer i will try to dig out some old pictures of mine, from memory they were easy to see the difference in them.
Colin
Here you go, Colin.
Exactly as I said:-
x 1463
Re: Xantia A/C
Unread post by xantia_v6 »
I think that you can see the wire numbers just peeking out of the sleeve.
Rhothgar
(Donor 2026)
x 221
Re: Xantia A/C
xantia_v6 wrote: 25 Oct 2023, 16:29 I think that you can see the wire numbers just peeking out of the sleeve.
Not with my eyesight.
I know what the wire numbers are anyway but then again I am fairly sure that the colours do not match the official manual which is more than irritating. What's the point of them if they contain inaccurate information?
x 1463
Re: Xantia A/C
Colours are irrelevant on Xantia wiring, only the wire numbers matter.
Rhothgar
(Donor 2026)
x 221
Re: Xantia A/C
xantia_v6 wrote: 25 Oct 2023, 17:14 Colours are irrelevant on Xantia wiring, only the wire numbers matter.
That's what a mate said about French cars in general.
I didn't believe him. Why do Citroen put colours in their manuals if not relevant, do you know?
Most of the time they are right but sometimes they are way off.
x 8408
Re: Xantia A/C
Rhothgar wrote: 25 Oct 2023, 17:17
Yes, because they're French ;)
Rhothgar
(Donor 2026)
x 221
Re: Xantia A/C
CitroJim wrote: 25 Oct 2023, 17:20
Les intendants du bar! :taz:
admiral51
(Donor 2026)
x 391
Re: Xantia A/C
Hi Roger
Have a look at This Thread
2nd or 3rd post says about pins 1+2 need to be bridged to engage the clutch on the compressor
Colin
