Wonder how much of the mirror I have to dismantle to get that back in
3008 door mirror
- x 1493
3008 door mirror
My car has developed a bit of a whistle from the passenger side (outside, not in the seat
), had a look today, and part of the mirror housing has come away. You can just see the gap at the end of my finger.
- x 3296
Re: 3008 door mirror
"First, remove the engine from the vehicle (see chapter 715 for this procedure), then...".RichardW wrote: 15 Oct 2023, 18:35 My car has developed a bit of a whistle from the passenger side (outside, not in the seat), had a look today, and part of the mirror housing has come away.
Wonder how much of the mirror I have to dismantle to get that back in![]()
- x 1493
- x 6945
If you can remove the glass first, then you should be able to see the shell clips from the inside Richard:
- x 1493
Looks like it might not be too hard, the part which is displaced is the rear 'body' which in this vid comes off fairly simply after removing the glass and 4 screws....
- x 1493
Fixed it - no parts, or even tools, required! Whilst outwardly similar to the mirror in that vid construction is different, there are no internal screws. A bit of a wiggle and the rear part of the cover came loose enough to re-engage the clip at front corner and snap it back together. Will see later if it fixed the noise. Emboldened I then took the glass out the drivers door - the heater has never worked. Sadly it was not disconnected, and the heater is not open circuit, connections a bit loose so I squeezed them up, but I doubt that's it, so (probably) haven't fixed that...
- x 1493
Ha! Fixed the heated mirror
Just popped the mirror out to see if you can get at the puddle lamp, which has also never worked. Indeed you can, just enough room to pop it out the mirror. With it out, bulb is OK, but it occured to me that the wires to the bulb looked much thicker than those to mirror, and colours were different to the other side. Has some one been here before....??? So
And we get
Wires swapped and heated mirror and puddle light both restored
And we get
PaulC5
- x 697
When the car is doing a dpf regen, it might put on the heated mirrors and other things to increase the engine load. Before you swapped the wires back, did you ever notice if the puddle light came on whilst driving ?
- x 6945
The rear 'external Lateral Lights' as they are referred to are on a separate circuit to the heated mirror control.
3018B : control of the exterior lateral lights where I've marked in yellow.
8112 : control of the protected heated mirror where I've marked in red.
- x 1493
Exactly, which is why the light is on when the HRW is on when the wires are connected up wrong!GiveMeABreak wrote: 22 Oct 2023, 11:51 The rear 'external Lateral Lights' as they are referred to are on a separate circuit to the heated mirror control.
- x 1493
Never saw it, but it must have been on!PaulC5 wrote: 22 Oct 2023, 11:32 When the car is doing a dpf regen, it might put on the heated mirrors and other things to increase the engine load. Before you swapped the wires back, did you ever notice if the puddle light came on whilst driving ?
- x 6945
Ah, so bodgit and leggit have been there before then!RichardW wrote: 22 Oct 2023, 11:55Exactly, which is why the light is on when the HRW is on when the wires are connected up wrong!GiveMeABreak wrote: 22 Oct 2023, 11:51 The rear 'external Lateral Lights' as they are referred to are on a separate circuit to the heated mirror control.
