- x 1480
c16rkc
- x 104
Any chance I can have numbers for the nut and bolt shown as 20 and 72 in the below.
Somehow I've managed to lose mine... I suspect the kids!
drayton11
Could I please have the part number for the passenger side outer CV joint. My VIN number is VF3**************[VIN obfuscated, can be read by forum staff] many thanks David
- x 6954
(20) Flanged Bolt, part: 9683866580, £5.45c16rkc wrote: 15 Oct 2023, 12:29 Any chance I can have numbers for the nut and bolt shown as 20 and 72 in the below.
Somehow I've managed to lose mine... I suspect the kids!![]()
(72) Flanged Nut, part: 693665, £12.76 (Pack of Four)
- x 6954
Your Vin's wrong, should be LHAH, but I have it now anyway.drayton11 wrote: 15 Oct 2023, 12:37 Could I please have the part number for the passenger side outer CV joint. My VIN number is VF3**************[VIN obfuscated, can be read by forum staff] many thanks David
(1) New Original OEM Driveshaft, Left, part: 9804894680, £511.88
(1) Peugeot Exchange Driveshaft, Left, part: 1610276180, £307.33
All VAT inclusive from Peugeot, and requires £144 deposit refundable on return of old unit.
dylan26__
- x 22
i'd like to replace the Crankshaft pulley too while doing this. have you got a Pt number for that?GiveMeABreak wrote: 03 Oct 2023, 23:19 There is indeed, The kit (50) includes the belt (20) and the Tensioner Roller (8):
(50) Ancillary Belt Roller Kit
OEM Original Kit, part: 1611277880, £127.36
DS Cheaper Alternative Kit, part: 1613444880, £38.10
- x 6954
(8) Single Damping Pulley, part: 0515T3, £195.56
(9) Pulley Screw, part: 1682800780, £8.66
dylan26__
- x 22
what is 7 & 5 in that diagram? should those be replaced with the pulley?GiveMeABreak wrote: 15 Oct 2023, 20:38
- x 6954
(5) Is one of the the crankshaft Seals.
(7) Is the Engine Timing Gear
I shouldn't think you would need to replace the gear (7), but if you did you would ned the seal (5).
But important you have all the correct setting rods and tensioner compression lever tools for the ancillary belt if going to do this yourself.
Rhothgar
- (Donor 2026)
- x 222
Me again!
Marc. Please can I have sight of the fiche(s) for the air conditioning system on X435.
Specifically, I am looking at seals as I am about to get the system regassed as first stage in getting to diagnosing the issue with it. I'd like to able to see the pipe runs and joints so I get a clearer picture of how hellish a job it is going to be replacing all the pipe seals...
Thanks in advance (of more pain
- x 6954
| Compressor | Evaporator Valve |
| Condenser | Freon Pipes |
(3) O-Ring seal (DIAM INT 10,82), part 6460V0, £1.31
(4) O-Ring seal (DIAM INT 17,17), part 6460V1, £1.45
Freon Pipes
(6) O-Ring seal (DIAM INT 10,82), part 6460V0, £1.31
(7) O-Ring seal (DIAM INT 17,17), part 6460V1, £1.45
(8) O-Ring seal (DIAM INT 20,22), part 6457R5, £3.44
(9) O-Ring seal (DIAM INT 7,65), part 6460T9, £1.49
Condenser
(5) O-Ring seal (no dimensions), part 6460C2, £1.45
Rhothgar
- (Donor 2026)
- x 222
Thank you Marc. Condenser 7 and 9 look fun to replace! They look like they sit against the bulkhead in some easily accessible position.
I am really surprised to see that there is no pipework inside the car.
Are seals 3 and 4 on Evaporator listed as nitrile seals (I've no idea where the evaporator valve is - is it behind the dash no doubt?)
Could I have part numbers and any extended sizing information for the following please:-
Evaporator Valve Fiche Seals 3 and 4
Condenser Fiche Seals 6, 7, 8 and 9
Freon Fiche Seal 5
Many thanks.
Freon Fiche Seal 5
Many thanks.
- x 6954
I didn't include pipework for the heating system (Matrix etc.), but here:
| Heating Hoses | Heater Detail | Regulator Housing & Probes |
Rhothgar
- (Donor 2026)
- x 222
That's fine. That's just the rubber hosing so I'm not concerned with that but useful at some point no doubt.
vallium
- x 15
Just saw this thread
Could somebody please give a correct turbo pressure transducer/Charge air corrector part number for VIN VF7**************[VIN obfuscated, can be read by forum staff].
If of any help it should be either 1618X2/9661960380/PIERBURG 7.01633.04.0 or 1618JH/9652570180/PIERBURG 7.00968.04.0
