DTC's after the car has been standing for a year 2013 Citroen DS3 1.6 eHDI
Looneytunes
My wifes car has been standing for a year i have finally got round to looking at it, these DTC's have come up when i got it started i wanted to check the wiring for the yaw sensor but can not find it anyone have an idea where it is located in a 2013 Citroen DS3 1.6 eHDI Thank you.
Looneytunes
Re: DTC's after the car has been standing for a year 2013 Citroen DS3 1.6 eHDI
Have got a bit further with this i had access to the AS/ESP pump and ecu i took the plug to the ecu off and water poured out what are your thoughts on if i dry the plug and the pins it goes onto and plug it back in is there a chance it could work again with no faults.
Thank You Stephen.
Thank You Stephen.
- x 1486
If there's no corrosion there's a good chance, but only one way to find out!
Looneytunes
Thank You for your reply there is no corrosion so fingers crossed will let you know how i get on.
Looneytunes
an update i have got more DTC's now
BSI
F52A Fault on the BSI:Outputs inhibited definitively (see parameter measurement status of the power outputs)
F062 Fault : no communication with audio ECU
FFF1 Battery charge status unit : voltage sensor fault
Engine ECU
U1218 Intersystems CAN
P16B4 ECU
P0693 Fan unit
P0493 Fan unit
P0691 Fan unit
ABS / ESP ECU
C1389 Fault : brake fluid level to low
C1302 "braking pressure sensor signal" fault
C1315 Lateral acceleration sensor fault
C1310 Yaw sensor signal Fault
Battery charge unit
FFF1 Voltage sensor fault
Multi functional Display
Global Test Report
ABS / ESP - ECU not recognised
Electro hydraulic power steering - ECU not recognised
Instrument panel - ECU not recognised
Radio - communication error
E
BSI
Engine ECU
P16B4 ECU
P0693 Fan unit
P0493 Fan unit
P0691 Fan unit
ABS / ESP ECU
Battery charge unit
Global Test Report
E
Carlos Fandango
Did you find the problem?
I’m currently diagnosing a C1302 and from what I’ve learnt and your symptoms you still have an issue with the plug on the ABS pump/ESP ECU.
The plug on there has wires connecting it to the BSI
- x 6957
It's connected to a lot more than the BSI.... It's a multiplexed CAN vehicle and the ESP system connects to both the BSI, the Engine ECU, engine fuse box and other sensors and systems.
