Peugeot 807 gyroscope sensor location
McWarnaly
Hi, does anyone know where the gyroscope sensor of 807 located?
- x 6955
Re: Peugeot 807 gyroscope sensor location
There's 2, one on the left and one on the right.
Access requires the deactivation of the airbag system and battery disconnection first, then on each side, partial removal of the front door seal trim where it meets at the lower middle part to provide access to the sill trim bolts.
These bolts are then removed along with the moulding to reveal the airbag acceleration sensor brackets with 4 bolts. Remove these to reveal the connector and the sensor.
- x 1044
Im getting the impression the OP means the gyroscope for the ESP?? Yaw sensor?
They are normally located on the floor of the cab behind the airbag ECU.
- x 6955
Possibly - so just to clarify the info I gave was for the Airbag acceleration sensors - so if it's the ESP inertia unit, then it's usually located in the centre of the vehicle somewhere in the front between the front seats on a car where the centre binnacle would be. With the gear controls mounted on the dash on these, it may be underneath there near the floor though, but I can't say for sure.
