Hi all,
Does anyone know if our gracious hosts, GSF, stock a replacement LHM reservoir top rubber seal. I’ve done a search but can’t find anything… Alas nothing new there !! [:o)][;)]
My one is leaking all over reservoir, despite cleaning it and seal twice…
Cheers
Steve
Replacement LHM reservoir top rubber seal
jeremy
dnsey
- x 19
sbraud
johnlyn
KevMayer
- x 8061
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by KevMayer</i>
I get a puddle of LHM on top of my reservoir too.
My level is correct but each time I open the bonnet there is a puddle of green martian blood.
Maybe its the result of running down invisible aliens !!
That gave me a good giggle... Maybe that is what LHM is. Martian blood...
I have the same problem. Somehow I think all Xantias have this condition..
I ignore it. I just wipe it up every time I check the oil and water.
- x 94
there are three posible causes for citro/blood being found on top of tank,
(1)being the usual to much fluid in tank,a lot of people dont know how to check this corectly
(2)missing the apature when topping up citro/blood
(3)posibly a leak from one or more of the rubber unions where pipes leave the tank
to check you level park car on level ground fully up on the highest setting,at this point the yellow disc not the copper one should be inbetween the two red bands on the level indiccator regards malcolm
- x 94
Kowalski
- x 1238
- x 94
sbraud
<hr noshade size="1"><font size="1"> I have a spare if required complete assembly, but from a 95 1.9TD LX not sure if same as VSX
John</font id="size1"><hr noshade size="1">
Cheers John I'll look into compatibility... although I think they'll be the same. How much are asking? And am I right in thinking tank, seal & central tube cluster?
Steve
Steve
