2007 Citroen C5 1.6HDi Engine cooling fan wont stop afterengine turn off
numanoo
Unread post by numanoo »
Hi
I have a 2007 Citroen C5 1.6HDi .
My problem is that the engine cooling fan continues to run long after engine turned off. Thus flattens battery.
Coolant levels and coolant/engine temp all look ok.
It is an intermittent fault.
I asked some adivice at local garage and was advised it was a "relay"
I think it maybe something attached to the main fan assembly but not sure??
I cant find anything about the relay online in order to buy one???
Any help much appreciated.
Numanoo
PaulC5
x 681
Re: 2007 Citroen C5 1.6HDi Engine cooling fan wont stop afterengine turn off
Unread post by PaulC5 »
You could do with plugging in a code reader that does live data. Other than your relay possible fault, other things could include the engine temperature sensor is giving a high value or if you have a dpf it might be trying to do a regeneration when the engine is switched off.
We had a 2010 C3 petrol and the fan on that kept running for a long time - it turned out there had been a bad batch of temp sensors and Citroen did a recall/technical note to replace them but it was a recall where you only found out if you went to a Citroen dealer with the fault.
x 1056
Unread post by wheeler »
The cooling fan relay (number 3) should be located on the fan cowling. It can easily be tested with a multi meter so dont just go replacing it without getting it checked properly.
numanoo
Hi , Thanks for the info I will check these options out.
I was looking to find item 3 (cooling fan relay) online but cannot seem to find this?? Has anyone got a link to one so I can source it if needed.
Many thanks for all your help
x 1070
Unread post by Rp0thejester »
My C8 had the same issue after I bought it and drove 200 miles home, fan over ran, next morning the battery was dead. You can go down the replacement route but before you get the parts the best thing I found to do, was start and stop the engine, I do it 5 times, if the fan hasn't stopped I disconnect the battery. But I'm lucky, the battery is next to my feet with a quick release
numanoo
