Hello.
I have some sort of exhaust leak in my van. When stationary fumes come into the cab via the battery tray.
Code reader says 5th injector atomiser which I’ll have a look at shortly.
When I took it to my local garage they said the turbo needs replacing. Looking underneath there does seem to be a lot of soot on the turbo exhaust manifold but before I jump in and replace the turbo does anyone have any other suggestions?
Also, I have read it’s far better to buy a recon oem turbo rather than new non oem one. Does anyone know any good refurbished sellers?
From inspection, I imagine I need to remove sub frame, disconnect, remove turbo and refit. Oil change and filters whilst I’m at it?
Thank you.
Citroën Relay Exhaust Leak
OnlinePaul-R
- x 1943
Re: Citroën Relay Exhaust Leak
On what basis did the garage diagnose that the turbo needed replacing? What tests did they do?
Adamhratcliffe
They didn't actually say. It's a local small garage and it was the guy's wife who I spoke to because the main guy had gone home. Is there anything I can do to test? When driving, I can view the pressure via my OBD ready and it changes when I accelerate. I wouldn't say the van feels particularly sluggish but I haven't driven any others to compare.
cornishrelay
I have the same issue with my 2019 2.0 fuel economy is poor too. Did you ever resolve this?Adamhratcliffe wrote: 25 Sep 2023, 10:07 Hello.
Thank you.
