Blue smoke C5 X7 2.0l HDi
Milordas
Unread post by Milordas »
Hello,
today when I was at the gas station and was waiting for others to fill up their tanks I noticed big cloud of blue smoke coming from my car. I turned off the engine and turned it on and of again like 2 times and after the second time blue smoke was gone. No warning lights, nothing out of the ordinary. The car ran good after that, no loss of power, no blue smoke and everything seemed normal.
What could be the possible cause of this cloud of blue smoke?
x 1066
Re: Blue smoke C5 X7 2.0l HDi
Unread post by Rp0thejester »
Could possibly be your dpf regenerating, were you driving for awhile before you went to the fuel station?
Milordas
I drove around 5km (3.1 miles). But DPF regeneration should rise rpm's a little bit and warning light should come up, no?
x 1066
No not really, it doesn't sound like the DPF was regenerating at only 3 mile drive. Could be an egr issue or worse case oil is burning
x 1935
No and no.
The revs wouldn't rise as that would mean the car would speed up! What happens instead is that the heated rear window and door mirror heaters are switched on so that there's more load on the engine which in turn raises the temperature of the exhaust for regeneration.
There's no warning light unless you fit one to the door mirror (usually driver's) which will glow whenever it's switched on.
x 1066
Paul-R wrote: 31 Aug 2023, 18:43 No and no.
I think my son has read your Homer Simpson quote, it would explain alot....
x 1066
Personally I wouldn't worry, it seems like it's nothing to worry about, could just be blowing rubbish out of the cat. If it happens more often then it should be investigated, but apart from that relax! It's part of the fun owning a Citroen
Milordas
Rp0thejester wrote: 31 Aug 2023, 18:40 No not really, it doesn't sound like the DPF was regenerating at only 3 mile drive. Could be an egr issue or worse case oil is burning
My first thought was that the oil was burning. Strange that it stopped and didnt came back.
Milordas
Rp0thejester wrote: 31 Aug 2023, 19:03 It's part of the fun owning a Citroen
Yes, but for me it's worth it!
darbuck
x 291
Unread post by darbuck »
Did you ever figure out what was wrong with your C5
Darren
Milordas
No I did not. It was a one-time incident and did not happen again.
darbuck
x 291
Just saw your post now thanks for letting me know
Darren
