Peugeot RCZ advice
ivanflex
Peugeot RCZ advice
Unread post by ivanflex »
Hello ,
I wanted to ask about throttle body, my car is RCZ 2.0hdi and on a car is throttle body with double electronics and double vacuums, but car (motor) has only one vacuum hose and only one electronic cable to connect, so I want to ask is it ok or someone change it somewhen and put with double throttle body? Car always put "check" on display for throttle body :shock:
x 6945
Re: Peugeot RCZ advice
No it can be normal as modifications were made, so perfectly normal to have one not connected.
ivanflex
But at around 3100-3300 rpm throttle gas block and put "check" engine, when I put it on diagnosis it put mistake for throttle body, maybe is problem second vacuum which is not connected? If I bought with one vacuum and one electronic and disconnect this hose (no 1 on photo) will it make some damage on motor or not
Graham369
Unread post by Graham369 »
Any diagrams of location of control module throttle actuator on 2012 rcz 1.6
electronmirror
x 30
Unread post by electronmirror »
Graham, the post that you appended yours to is 3 years old, the Diagnostics section is more related to questions about test gear used to diagnose faults on cars.
I suggest you repost your query, which is about a different engine type anyway, in the Peugeot section of the website.
Hope this helps
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
