Peugeot RCZ advice
ivanflex
Peugeot RCZ advice
Unread post by ivanflex »
Hello ,
I wanted to ask about throttle body, my car is RCZ 2.0hdi and on a car is throttle body with double electronics and double vacuums, but car (motor) has only one vacuum hose and only one electronic cable to connect, so I want to ask is it ok or someone change it somewhen and put with double throttle body? Car always put "check" on display for throttle body :shock:
x 6953
Re: Peugeot RCZ advice
No it can be normal as modifications were made, so perfectly normal to have one not connected.
ivanflex
But at around 3100-3300 rpm throttle gas block and put "check" engine, when I put it on diagnosis it put mistake for throttle body, maybe is problem second vacuum which is not connected? If I bought with one vacuum and one electronic and disconnect this hose (no 1 on photo) will it make some damage on motor or not
