Steering Rack boot......right side on a LHD v.6 Activa
- x 1996
I am struggling with a steering rack boot.
------(Right hand side/LHD drive V6 Activa)
The boot has popped of (at red arrow) and I cannot work out a way of reattaching it .... I thus cannot secure it with a new ligature.
Does anyone have advice about the best way to do this job ?
Getting my hands in there seems imposable !
- x 1488
Re: Steering Rack boot......right side on a LHD v.6 Activa
Imagine it will be down to which is easiest to remove...rack, subframe, or engine!!
- x 8391
RichardW wrote: 27 Aug 2023, 15:33 Imagine it will be down to which is easiest to remove...rack, subframe, or engine!!
- x 1459
Are you fitting an original style stiff plastic boot, or an aftermarket rubber boot?
- x 1488
It's of no help to Sticky, but this amused me when I first saw it 30+
years ago....
- x 8391
RichardW wrote: 27 Aug 2023, 21:00 It's of no help to Sticky, but this amused me when I first saw it 30+years ago....
I had a long chat with Alasdair about this last evening and suggested it might be best to remove the rack... I've never done the job, except on a scrapper with no engine, so I'll be interested to know how it goes...
- x 1996
Just trying to slip a rubber boot back on.....strapping has failed so it has popped off (has been on about 5 years)xantia_v6 wrote: 27 Aug 2023, 19:12 Are you fitting an original style stiff plastic boot, or an aftermarket rubber boot?
- x 1996
I have no clue what that is about...sorry, over my head that oneRichardW wrote: 27 Aug 2023, 21:00 It's of no help to Sticky, but this amused me when I first saw it 30+years ago....
- x 8391
As I read it, the bit about the engine being removed for clarity...Stickyfinger wrote: 28 Aug 2023, 11:03
- x 1996
Ahhh...
Rip the engine out with a fork-lift and an angle grinder ....is how I feel atm
- x 8391
Now then Alasdair, behave yourself! I once ripped a V6 engine out with an angel grinder but that was a in a scrapper... Yours isn't...Stickyfinger wrote: 28 Aug 2023, 20:25 Ahhh...
Sounds to me that a special tool is needed, one designed and made buy an enterprising fitter.
Then add it to this thread.
DIY Car Maintenance with function over finesse!!
- x 1996
Fail.....it popped off on full lock......just cannot get it set tight before crimping.
Round two.....struggle to get the boot back on....AGAIN !
This time I will try jubilee clip....It is a good type.... and it fits in the grove in the boot neck
- x 1996
Update:
Attempt No2.... This is the method using a same size socket, a matching boot and the same type of jubilee clip.......this shows how tight it can grip.
I gripped the socket in my vice and pulled the boot as hard as I could, it did not come off (nor did the socket launch itself at my face.....that "errr moment of danger came after the experiment ! )
and this the same on the car......I am showing the boot at full steering lock so max stretch.
I will leave it like this all day to test/see if it slips off and maybe "set" the rubber boot (if it does such a thing)......
I will fold the "tail" of the clip out of the way of the boot later to make sure it does not catch and damage it.
- x 8391
Excellent work Alasdair
