mickthemaverick wrote: 20 Aug 2023, 21:16 Discussion on POTD has suggested Jim should get a T-shirt signed around the world so I thought a little 'where is this then' might prove amusing over the next 8 days. So you need to identify Jim's whereabouts each day!!:
Number 1
Whatsthisthen?
OnlineRp0thejester
- x 1077
Re: Whatsthisthen?
Champion of Where's CitroJim
- x 3565
Re: Whatsthisthen?
Once you've got the loaf out and the tin has cooled down, put just enough water in to cover the paddle and let it soak for a minute or two - it'll come out no problem then.mickthemaverick wrote: 20 Aug 2023, 19:01 Yes a kind of simple puller. You just slide the notch around the spindle under the paddle, rock it side to side and it levers the paddle up sufficiently to break the dough seal, then just pull straight up to release the paddle.![]()
OnlineRp0thejester
- x 1077
Re: Whatsthisthen?
I'm gunna guess at Sydney
- x 8144
Re: Whatsthisthen?
That is what the instructions say but it simply didn't work, soaked in hot water for 30 mins and still stuck!! However butter worked a treat so that will be the method in future, no effect on the loaf at all!!bobins wrote: 20 Aug 2023, 21:19Once you've got the loaf out and the tin has cooled down, put just enough water in to cover the paddle and let it soak for a minute or two - it'll come out no problem then.mickthemaverick wrote: 20 Aug 2023, 19:01 Yes a kind of simple puller. You just slide the notch around the spindle under the paddle, rock it side to side and it levers the paddle up sufficiently to break the dough seal, then just pull straight up to release the paddle.![]()
- x 8144
Re: Whatsthisthen?
First points go to Ryan!! Stay tuned for tomorrows destination!!
OnlineRp0thejester
- x 1077
Re: Whatsthisthen?
How many points do I get???
- x 8144
Re: Whatsthisthen?
Just to make it clear for the rest you need to identify where Jim is in the picture, as Ryan has done, not what is in the pictures!!
- x 8144
Re: Whatsthisthen?
50 points per place identified!
- x 8144
Re: Whatsthisthen?
Number 2
- x 3296
Re: Whatsthisthen?
Rio de Janeiro?
- x 5674
Re: Whatsthisthen?
Christo Redentor
Not the best track on the album.
- x 8144
Re: Whatsthisthen?
Today's 50 points go to James for Rio where Jim can be seen mixing with the crowd!
OnlineMattBLancs
- x 2362
Re: Whatsthisthen?
Rio de Jim-near-o ?
- x 8144
Re: Whatsthisthen?
Number 3
- x 3296
Re: Whatsthisthen?
Taj Mahal, Agra.
