mickthemaverick wrote: 20 Aug 2023, 21:16 Discussion on POTD has suggested Jim should get a T-shirt signed around the world so I thought a little 'where is this then' might prove amusing over the next 8 days. So you need to identify Jim's whereabouts each day!!:
Number 1
Whatsthisthen?
- x 1083
Re: Whatsthisthen?
Champion of Where's CitroJim
- x 3565
Re: Whatsthisthen?
Once you've got the loaf out and the tin has cooled down, put just enough water in to cover the paddle and let it soak for a minute or two - it'll come out no problem then.mickthemaverick wrote: 20 Aug 2023, 19:01 Yes a kind of simple puller. You just slide the notch around the spindle under the paddle, rock it side to side and it levers the paddle up sufficiently to break the dough seal, then just pull straight up to release the paddle.![]()
- x 1083
Re: Whatsthisthen?
I'm gunna guess at Sydney
- x 8151
Re: Whatsthisthen?
That is what the instructions say but it simply didn't work, soaked in hot water for 30 mins and still stuck!! However butter worked a treat so that will be the method in future, no effect on the loaf at all!!bobins wrote: 20 Aug 2023, 21:19Once you've got the loaf out and the tin has cooled down, put just enough water in to cover the paddle and let it soak for a minute or two - it'll come out no problem then.mickthemaverick wrote: 20 Aug 2023, 19:01 Yes a kind of simple puller. You just slide the notch around the spindle under the paddle, rock it side to side and it levers the paddle up sufficiently to break the dough seal, then just pull straight up to release the paddle.![]()
- x 8151
Re: Whatsthisthen?
First points go to Ryan!! Stay tuned for tomorrows destination!!
- x 1083
Re: Whatsthisthen?
How many points do I get???
- x 8151
Re: Whatsthisthen?
Just to make it clear for the rest you need to identify where Jim is in the picture, as Ryan has done, not what is in the pictures!!
- x 8151
Re: Whatsthisthen?
50 points per place identified!
- x 8151
Re: Whatsthisthen?
Number 2
- x 3298
Re: Whatsthisthen?
Rio de Janeiro?
- x 5676
Re: Whatsthisthen?
Christo Redentor
Not the best track on the album.
- x 8151
Re: Whatsthisthen?
Today's 50 points go to James for Rio where Jim can be seen mixing with the crowd!
- x 2366
Re: Whatsthisthen?
Rio de Jim-near-o ?
- x 8151
Re: Whatsthisthen?
Number 3
- x 3298
Re: Whatsthisthen?
Taj Mahal, Agra.
