x 6946
(2) Exhaust Gas Temperature Sensor, part: 1618PG, £187.51
x 22
Unread post by 407 »
Thanks Marc
so the module is in the stalk itself ?
regards
x 6946
I've never seen that other component you pictured. The Cruise Control module is that stalk unit that interfaces with the Comms Unit and the engine ECU / BSI.
darbuck
x 289
Unread post by darbuck »
GiveMeABreak wrote: 16 Aug 2023, 20:46 Image
Thanks Marc
Darren
darbuck
x 289
Hi Marc, can you give me the part number for reverse switch for my C5 please? And if possible replacement procedure.
Darren
x 6946
(13) Reversing Lamp Switch, part: 225753, £22.16
darbuck
x 289
Thanks a million Marc
Darren
Kernowjon
Unread post by Kernowjon »
Hi Can you find a part number for the under bonnet wiring loom of
1997 Peugeot Expert 1.9D bus
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Also is the RHD and LHD loom the same
x 6946
(1) Engine Electrical Harness (MARKING: 1480542080 1480955080 1478865080 1481948080 1480956080), part: 6549L9 (No Longer Available from Peugeot).
The harnesses differ on build date, equipment and are different for Left Hand Drive.
c.morewood
x 55
Unread post by c.morewood »
Good afternoon Marc,
Citroen C3
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Please could I have the part nos for:
1. Front NS ABS sensor.. there are 2 lengths, I'm not sure which one I need.
2. At the back of the gearbox( according to the garage ) is a rubber mount preventing the gearbox contacting the chassis. I need this mount no please?
Thanks, have a good weekend.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
x 6946
(1) ABS Wheel Sensor (Front), part: 454597, £88.61
There's only 2 ABS Wheel sensor parts - one for the front and one for the rear. :wink: The sensor shown at (2) is the rear one.
As for the gearbox mounts - this is the engine fixing diagrams which include any gearbox mountings IIRC. So if you can identify it, let me have the item number:
c.morewood
x 55
Thanks Marc, I'll have to use a friend's garage to get under and take a decent peek. I'll get back to you.
'94 Fiat TipoTd 40K
KennyW
x 165
Unread post by KennyW »
Marc,
Can you provide the part number for the Turbo on my C5 x7 ?
Kenny
C3 1.4 petrol (SWMBO)
x 6946
(1) New Turbo, (HONEYWELL INDUS - GTB1449VZ) HONEYWELL INDUS - 783248, part: 9677062780, £1,617.36
Exchange Turbo (HONEYWELL INDUS - GTB1449VZ) HONEYWELL INDUS - 806500, part: 0375S8, £851.93
WindyMiller
Unread post by WindyMiller »
Hello, can I put a request in for:
I am after diagrams and part numbers for all of the engine and gearbox mounts please.
