- x 6960
(2) Exhaust Gas Temperature Sensor, part: 1618PG, £187.51
- x 22
Thanks Marc
so the module is in the stalk itself ?
regards
regards
- x 6960
I've never seen that other component you pictured. The Cruise Control module is that stalk unit that interfaces with the Comms Unit and the engine ECU / BSI.
darbuck
- x 291
darbuck
- x 291
Hi Marc, can you give me the part number for reverse switch for my C5 please? And if possible replacement procedure.
Darren
- x 6960
(13) Reversing Lamp Switch, part: 225753, £22.16
darbuck
- x 291
Kernowjon
Hi Can you find a part number for the under bonnet wiring loom of
1997 Peugeot Expert 1.9D bus
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Also is the RHD and LHD loom the same
- x 6960
(1) Engine Electrical Harness (MARKING: 1480542080 1480955080 1478865080 1481948080 1480956080), part: 6549L9 (No Longer Available from Peugeot).
The harnesses differ on build date, equipment and are different for Left Hand Drive.
c.morewood
- x 55
Good afternoon Marc,
Citroen C3
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Please could I have the part nos for:
1. Front NS ABS sensor.. there are 2 lengths, I'm not sure which one I need.
2. At the back of the gearbox( according to the garage ) is a rubber mount preventing the gearbox contacting the chassis. I need this mount no please?
Thanks, have a good weekend.
Citroen C3
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 6960
(1) ABS Wheel Sensor (Front), part: 454597, £88.61
There's only 2 ABS Wheel sensor parts - one for the front and one for the rear.
The sensor shown at (2) is the rear one.
As for the gearbox mounts - this is the engine fixing diagrams which include any gearbox mountings IIRC. So if you can identify it, let me have the item number:
c.morewood
- x 55
Thanks Marc, I'll have to use a friend's garage to get under and take a decent peek. I'll get back to you.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
KennyW
- x 163
Marc,
Can you provide the part number for the Turbo on my C5 x7 ?
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6960
(1) New Turbo, (HONEYWELL INDUS - GTB1449VZ) HONEYWELL INDUS - 783248, part: 9677062780, £1,617.36
Exchange Turbo (HONEYWELL INDUS - GTB1449VZ) HONEYWELL INDUS - 806500, part: 0375S8, £851.93
WindyMiller
Hello, can I put a request in for:
I am after diagrams and part numbers for all of the engine and gearbox mounts please.
