V6/24 ES9A distribution set replacement
Kees
x 147
Unread post by Kees »
Hello, forrummers.
I need to chance my distribution set.
It's a Citroen C5X7 with the 3.0/24 ES9A engine.
Is there sombody here with experience or with an "how to" discription.
Greetings.
Kees.
x 6957
Re: V6/24 ES9A distribution set replacement
Here's the official procedure for this operation:
C5 X7 3.0 Petrol ES9A Timing Belt Replacement
Kees
x 147
Thanks, Marc!!!
handyman
Unread post by handyman »
Hullo Marc, the link wont open, saying I'm not authorised, even though I'm logged in.
x 1940
That'll be because it's information that the forum is charged for by Stellantis. A few years ago PSA (as then was) changed its policy and made information such as this and part numbers chargeable. The forum staff took the decision to buy into this information but that any member wanting this type of information would have to step up the level of their membership to become a contributing member.
For the princely sum of £10 you will get access for the remainder of the current year plus the next year. So, up to two years' membership.
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Reason: Added remainder of Parts Service Text
x 6957
I've added the remainder of the text that should go with the above, as we do not supply PSA Technical Documentation as part of the PARTS service. Documentation in the Resources section is discretionary and dependent upon availability and time I have to write it up.
