ESp and DPF faults C4
luk_wro
Unread post by luk_wro »
Hi,
I have 2 main issues with my C4 Grand Picasso 1.6 HDi semi-automatic 2011.
The first one is an ESP fault, after changing tie rod end in my car and setting up axis alignment I start getting ESP faults. I check it using Delphi Scanner and it shows the:
- Steering wheel angle sensor; incorrect value received
- invalid data
- Intermittent
- Engine control unit, absence of clearing of the ASR/MSR reference value
- Intermittent
Second one is DPF, I change already EGR valve (mapping done) as it was showing that is not working, that`s gone. Also DPF differential pressure sensor is changed. Unfortunately i still have fault:
P1490 - Particle emission filter, overloaded
- Permament
P242F - Particulate filter clogged
- Permanent
Any ideas? I should change steering wheel sensor and DPF ?
x 1064
Re: ESp and DPF faults C4
Unread post by Rp0thejester »
Normally the ESP can be reset by holding the button in for 5 seconds.
x 1056
Unread post by wheeler »
The ESP system will likely need the steering angle sensor re calibrated since the tracking has been altered.
I would imagine your Delphi kit can do this.
x 6955
Rp0thejester wrote: 05 Aug 2023, 20:20 Normally the ESP can be reset by holding the button in for 5 seconds.
That has nothing to do with the system faults Ryan. Holding in the ESP button on older vehicles just disables ESP temporarily, but it will kick back in once a certain speed is reached or when the ignition is switched off and back on again.
luk_wro
wheeler wrote: 05 Aug 2023, 21:11 The ESP system will likely need the steering angle sensor re calibrated since the tracking has been altered.
I did it twice. Decalibrate and calibrate again. ESP fault back after a short distance.
x 1064
GiveMeABreak wrote: 05 Aug 2023, 21:33
I make those posts because you can't help but reply. If your aware the post it's more likely the OP will resolve their problem
x 1056
luk_wro wrote: 05 Aug 2023, 21:36
Might have been worth mentioning that?
luk_wro
ok i do some test using delphi and it show that ash in dpf is 0%. Its possible or its some mistake?
