Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
Apologies if this is not the correct place to post but...
Marc. Can I please have the relevant wiring diagrams for a Citroen ZX Immobiliser Circuit?
lisasherratt
Unread post by lisasherratt »
Hello
Please can I get the parts diagram of engine ancillaries DS4 2012 200THP for VF7**************[VIN obfuscated, can be read by forum staff] ?
Trying to locate an oil leak!
Many thanks in advance
x 6963
@lisasherratt: I moved your previous post and replied on 29th July - awaiting your response:
viewtopic.php?p=763645#p763645
x 6963
Rhothgar wrote: 02 Aug 2023, 15:22 Apologies if this is not the correct place to post but...
Unidentified Vehicle (and in any case, there is nothing available I have electrical wise for a vehicle this old, sorry).
Rhothgar
(Donor 2026)
x 222
GiveMeABreak wrote: 02 Aug 2023, 18:36
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Really? It’s a P reg 1.9TD SX trim.
I’ll double check VIN but that is off the VIN plate though it did need wire wool…
Rhothgar
(Donor 2026)
x 222
Oh! Just seen your update!! Yikes!
x 6963
There is nothing for vehicles this age on the database of electrical diagrams. They never bothered transferring the old low res diagrams into electronic format. We only just got Xantia MK II, but also have nothing for the XM. They may be available somewhere on Haynes or in paper format.
Huskyxantia
x 847
Unread post by Huskyxantia »
Good evening Marc Needing part number for an engine under tray 308cc vin VF3**************[VIN obfuscated, can be read by forum staff] many thanks.
:-D
x 1056
Unread post by wheeler »
Part no 7013EC £370.79 inc VAT from dealer
ThoreT
Unread post by ThoreT »
Hello again Marc
Would you be able to provide me with the part number for the green O-ring that sits on the high pressure pipe on the C5III electro pump?
Kind regards,
Thore
x 6963
The only O ring shown on the piping circuit for your vehicle is (92), but it doesn't say where it goes or for which pipe, so can't help you there:
(92) Steering O Ring Seal Internal Diameter 8.8 MM, part: 9832648080, £
Rhothgar
(Donor 2026)
x 222
Afternoon Marc. Hope you are enjoying your weekend.
Please can I have part numbers for EGR valve and gasket if separate on X435 JGJ please.
An internet search for a replacement part does match what I have!
Thanks in advance.
x 6963
Also refer to my reply on your other thread regarding this:
viewtopic.php?p=764555#p764555
(1) EGR Valve, part: 1628JZ, (No Longer Available from Citroen).
(3) Emission Control Circuit Seal, part: 16282N, £3.04
Rhothgar
(Donor 2026)
x 222
Cheers. Have replied already. Thanks for these. Can this be transferred to that post?
407
x 22
Unread post by 407 »
Hi Marc
Can you provide the part number for a Turbo Pressure Solenoid Valve for the Peugeot 407 2.7 HDi
Its the one that sits on the rear left hand side of the engine just behind the inlet manifold.
The numbers I found are 4M5Q9E882AA 70051800 SIEMENS
regards
