Peugeot Boxer gearbox capacity
Mikdb
Can anyone tell me the oil capacity of the gearbox on my Boxer motorhome. There is no level plug, just drain and fill. I want to change the oil. The VIN No is VF3**************[VIN obfuscated, can be read by forum staff] Thanks.
- x 1052
Re: Peugeot Boxer gearbox capacity
2.4 Litres for just a drain & refill or 2.7 Litres if its a dry gearbox or overhaul.
DEVON DOGG
I have had this before on modern stuff
I drain the oil then measure it in a jug and put back the exact about of new oil
Is the filler not also the level?
- x 1052
The only problem is you dont know if the level was correct in the first place, Could have had a clutch or gearbox repair done done & the previous person working on it never put enough in or even overfilled it.DEVON DOGG wrote: 31 Jul 2023, 10:48
These gearboxes are filled via the breather on the top of the box.
beelag
Hi can i put an additional query n this thread?
I have a 2014 (2013 manufacture) Boxer 2.2 130 with a manual 6 speed box. I wish to change gearbox oil to see if it improves slightly notchy gear changes when on sustained long hot runs (no notchiness when cold or normal driving) in case there is water ingress.
Trouble is there seems to be a lot of conflicting info on refill quantity depending on type of box.
My gearbox has the almost flat steel end cover, is it an MLUC or a MGLU they have different quantities for each? and which oil, is Total Traxium Gear 8 GL4 PSA B71 2330 correct
I also found the stampings on the gearbox:
20GP15
0489232
2.91
Got the attaching photo sorted with help from forum admin team, thanks.
Any help appreciated
Billy
20GP15
0489232
2.91
Billy
- x 5672
Check your PMs re: image posting Billy.
BogdanR
Hi, I have a 2019 boxer VF3**************[VIN obfuscated, can be read by forum staff] , can you help please, I want to change the gear box oil and i don't know how much oil goes in ?
- x 1938
This information from viewtopic.php?p=790637#p790637
ML6C Gearbox with fins will look like this:
And without fins like in beelag's post above.
The correct oil is 75/80 and must be GL4 spec, not GL5.
| ML6C | Gearbox casing without fins | Gearbox casing with fins |
| Drain and refill | 2,6 litres | 1,9 litres |
| After overhaul | 2,8 litres | 2,2 litres |
Shaune
- New User
Hi, I have a peugeot boxer 2002 1.9TD
can anyone tell me what the gearbox oil max capacity is & what type of oil to use ?
