Hi
The problem is precisely that it does not work or more precisely it does not work entirely.
In my case lexia is the tool that does the rest (actuator test, pairing, airbag, abs...)
And the 3£ obd does the rest, but for live data the software is not free and I would like to be sure that it is usable before spending 50£ on an application.
My ecu is a Sagem sp2-380 recognized as s2000pm1.
Many settings like ltft ,ignition (not move or lag extremely) or live data does not work (lexia directly tell me that the information will not be guaranteed because it does not recognize the ecu).
I will end up opening the case is physically checked if it is full or not
Thank you all
Lexia 3 read s2pm-380 C3 1.4i 8v 2002
- x 6955
Re: Lexia 3 read s2pm-380 C3 1.4i 8v 2002
If you are going to do that, put some pictures up of both sides of the boards.
Jooo000
Hi.
I tried to read again with diagbox 7.02.
I had the same results except that I realized that I could accelerate more than 3000rpm.
I have an error on the acceleration unit and on the computer.
I tried to erase but it says "cut during erasing" I'm afraid of having burnt out my ecu by simply trying to read the engine values
- x 6955
Any of the following faults: P0601, P0603, P0604 or P0606 refer to an internal fault of the Injection ECU. That being the case and if you have checked all the pin connections to the injection ECU and the wiring, then you may be looking for a new ECU. There is no further information about these faults apart from an internal fault.
Jooo000
Hi
I disconnected the battery and it's gone again...
Now it is ok
Now it is ok
Jooo000
Hi
I am looking for hardware and software to make logs.
I would like to give up lexia and its clone and found a good quality USB elm.
I read that there are 8bit, 16bit and 32bit
For the software I do not know what to choose.
Do you have any leads on correct hardware and software?
THANKS
THANKS
- x 6955
I can't helkp you, I only support the software (Lexia, PP2000 & Diagbox) with the VCI clone interface.
Jooo000
Hi!
After lot of tests and the fear of having broken my ecu, i put away my lexia and look for another more generic diagnostic tool like cl2000 Can loggers (especially for live data).
then I told myself that would still be interesting to open this tool...
it is not complete (lite version).
Obviously the problem does not come from the software but rather from the tool.
- x 6955
Yes, we know that, the cheaper versions have cut-down hardware and won't work properly with later vehicles.
There are other missing components not shown in the image above in the cheaper versions.
Jooo000
hi!
yes some people have the skills to add the "good" components.
I remain doubtful that a "full chip" improves operation, often the reference to full chip is for modern cars with completely impossible reading.
In my case I read some live values ??(slowly) without being able to save.
the actuator test works and it is apparently normal that my sp2m-380 ecu is read s20000pm1
Jooo000
