Peugeot 5008 1.6 petrol 2011 model
JOEgsd
New User
Unread post by JOEgsd »
Good morning, I'm having some electrical issues, it started with my car going dead 30 min after I had switched the ignition off and locked the car. Not beeing able to unlock the car with the remote, And clock always going back to 0:00. This still continues but now I have another isue, 2 to 5 minutes after I switch off the ignition, my headlights switch on all on there own, and run my battery dead.
x 6955
Re: Peugeot 5008 1.6 petrol 2011 model
Check for signs of corrosion on the connector of the 3 relay switching and protection unit. If this shows signs of corrosion, replace it.
When faulty this can cause activation of the headlamps and wipers after ignition is switched off and the BSI goes to sleep.
Having said that, you should really get a diagnostic done so see what other faults are showing then post them up.
