Change language RT3
BenC5-forum
Re: Change language RT3
Hello. You would do me a great favor, if you could send me an email with the link to the ISO file, so I will be able to transform it to a CD. The radio asks me to put in the configuration CD rom, that I do not have.
I own a Citroën C 2005. Got a problem with my radio when I bought it. Got a second hand radio, but no CD rom.
Many thanks in advance!
Regards,
Ben
Regards,
Ben
Reason: Email removed
- x 6946
I need to know what software version you have to start with as there is a VAN and a Full CAN version which are not compatible with each other. You need to go to the system settings to find out the version, like the other posters on the previous pages (look at the images).
- x 6946
Ok, that's fine you have the Full CAN version. I will send you a link via Private Message shortly.
BenC5-forum
Where can I find this private message?
OnlineHell Razor5543
- x 3296
At the top right of any Forum page (once you have logged in) is the Private Message tab.
Mladen
Can you please help me?
I need a firmware update CD (or ISO) for my car (peugeot 307, 1.6, 2006)
I need to change language to English.
I would be very grateful, thanks in advance!
antizero
Hello,i have a 2006 Peugeot 407 and i have the same problem? How can I access the language files?
- x 6946
Check the firmware version first what version do you have already?
Mladen
Well... no solution for my problem...
viewtopic.php?p=762186#p762186
- x 6946
@Mladen: Check your Private Messages. I sent a few requests out at the time and must of missed yours. The message and content is just forwarded to you to save me retyping.
Mitroisorin
- New User
Hello ! I have a peugeot 407 with rt3 i think, i cant change language to english, can anyone help me? Thank you!
Reason: Image fixed.
- x 6946
Firmware link will be in Private Message. How old is your car battery - as you have an issue with the clock resetting it seems (01/01/2000), otherwise I suspect the battery backup in the RT3 has failed - which is more likely to be the case for the age of the unit.
outsider80
Hello!
I Have a C4 Picasso 2006 with NaviDrive (RT3)
The language is german at the moment and it needs the original CD to change it to english.
Can you help me with the link for the cd image?
Thanks!
Thanks!
Reason: Removed VIN Image - Not Required
