Onlinemyglaren
- x 5670
Daughter fitting her laminate floor, then a cuppa before tackling the remainder of the kitchen renovation.
- x 1066
My boy sent me this, I thought it was weird but the more I follow it, it makes more sense
Reason: Image rotated
Champion of Where's CitroJim
- x 8083
It comes up upside down when I zoom in. If you edit the post yourself, delete the picture, then open the pic in paint, resize and set it up upright, save it and then add it back into the post it will come out as you had it in paint!!
- x 1066
Really? That ain't gunna happen. Thx MyGlaren
- x 8083
Doesn't need to now, Steve's done it for you!
- x 1066
I like the fact that you took the photo whilst sitting there doing nothing, sorry, drinking a cup of teamyglaren wrote: 15 Jul 2023, 11:31
Onlinemyglaren
- x 5670
She just gets on with things. Apart from a little help she has fitted her original kitchen from scratch, bought all the wood and cut it up with my circular saw, applied the laminate to the worktops etc. I helped with the plumbing, gas and electrical stuff. Current kitchen was prefabricated units and she had a fitter in to assemble them and fit the sink and worktops, she re-laid the floor and did all the painting.
I helped her move the shower and re-plum and rewire for it, fit a bath where there hadn't been one and fit a new washbasin for her but she did the rest including the tiling.
This is the third house she has done.
She's the same at work, does all sorts that aren't her job when she has time to spare. She has just started at a new place that is a five minute walk for her, instead of a forty minute drive. New place has less work but pays her more and she can work whatever hours suit her. She amazed the owner a couple of days ago starting work on a garden that has not been touched in years. It is a funeral directors and will improve things a lot for the appearance for clients.
- x 1066
I knew would reply, dangle that carrot.....myglaren wrote: 15 Jul 2023, 18:49 She just gets on with things. Apart from a little help she has fitted her original kitchen from scratch, bought all the wood and cut it up with my circular saw, applied the laminate to the worktops etc. I helped with the plumbing, gas and electrical stuff. Current kitchen was prefabricated units and she had a fitter in to assemble them and fit the sink and worktops, she re-laid the floor and did all the painting.
- x 8083
My picture for today has been unashamedly stolen from Jim's Sunday gallery of the Citroen Car Club National Meet!!
I find myself wondering if this is the first of a number of trailers which he intends to run as a C5 train?
Note the towbar still on the trailer!
You can find the link to Jim's full album in his post here!!
- x 2336
Can't help but wonder what's going on / replaced the hydraulics!?
The side skirts bent inwards to meet in the middle is a nice touch (a bit of "work in progress" / duck tape special further up!)
- x 8343
I spoke to the owner, Hannah, and she tells me the hydraulics are in full working order, as is the rear windowMattBLancs wrote: 16 Jul 2023, 19:58 Can't help but wonder what's going on / replaced the hydraulics!?
The rear-end came from a C5 that suffered a severe frontal...
Very much still a work in progress.. the front is to be massively improved in due course...
- x 2336
I'd spotted the rear window down (but incorrectly assumed it was just a "keep fit" manual winder type!)
There is one way to sort the front out, like this: (From https://images.app.goo.gl/gaY2VoPPNHfeQ8uZ8)
I'd imagine the problem with back end of a car as a trailer is generally not enough rear overhang, and so easily becomes quite nose-heavy if you've brought too much of the donor car across.
I'm not sure how well that twin axle Capri would take tight turns, with a fair gap between those axles, imagine quite a bit of scuffing goes on!
Love the idea of if all the same!
- x 2336
Ah, thinking about it, if it's a camper, likely a leisure battery on board (for lights etc when camping) - so that could deal with the high current, intermittent load of the hydraulic pump, trickle charged via the normal trailer socket rest of the time when in the move
- x 8343
- x 8083
We appear to have gained a new drive marker, presumably to help the 'refuse collection engineers' to put our wheelie bins back on the drive where they found them rather than on our grass!!
