What's wrong?
- x 2941
What's wrong?
The pointer on my computer keeps dashing off up to the top right and bringing down the settings menu.
- x 1057
Re: What's wrong?
Have you tried a reboot? Whilst turning your mouse upside down?
Champion of Where's CitroJim
- x 8068
Re: What's wrong?
Are you using a wireless mouse ?
- x 1057
Re: What's wrong?
Control,Alt, delete should force a shutdown. if anything is moved during loading it can think that 0 movement is somewhere else so will keep going to that direction after loading
- x 2941
Re: What's wrong?
Not wireless Mick but it's been playing up all since I started posting here today, typing away and suddenly it's off and down comes the menu.
Switching off now so I'll see if it's sorted when I restart in the morning.
- x 6955
Re: What's wrong?
Turn your mouse upside down and clean / remove any fluff from the optical sensor. If crud gets in there it can cause the tracking to go wild.
- x 2322
Re: What's wrong?
Once saw this problem (on the boss's laptop at work) in that case it was the "nipple mouse", central on the keyboard that had gone faulty. He never used that so I managed to turn it off using every keyboard shortcut I could muster to navigate about!
- x 1438
Re: What's wrong?
I have also had that problem with a touchpad mouse.
You should disable each pointer device until you find the culprit. You may be able to disable devices in the windows device manager.
On one PC I had to open up the machine and physically disconnect the pointer thing.
Sloppysod
- x 386
Re: What's wrong?
Well, we're all fidgitting in anticipation, can't stand the suspence...... Is it better this morning?Gibbo2286 wrote: 14 Jul 2023, 21:18 ....... now so I'll see if it's sorted when I restart in the morning.
Stu
- x 2941
Re: What's wrong?
So far it seems to be OK, will see how it goes during the day.
