NFU engine torque specs
jsp
x 12
Unread post by jsp »
Does anyone know how much torque on the waterpump bolts?
I did 20Nm seems a bit low
Its a Cast iron block not the aluminium one.
x 6955
Re: NFU engine torque specs
I'll need the VIN for the specific vehicle.
jsp
x 12
VF3**************[VIN obfuscated, can be read by forum staff]------2 --- NFUF 43030609
x 6955
That's no good to me, please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
x 1044
Unread post by wheeler »
The official torque setting is actually only 18 Nm. Wouldn't dream of only tightening them to that though. I cant say ive ever torqued a water pump bolt. just tighten them with a 1/4 drive ratchet.
jsp
x 12
x 6955
That VIN is invalid and missing one alpha / digit and even with the 7 added as the third character, it's still wrong somewhere on the last 8.
jsp
x 12
x 6955
Here - it is 20 N.m
ReferenceDesignationTightening procedure
(18)Bolts - Coolant PumpTightening to 2 m.daN
(19)Knock SensorTightening to 2 m.daN
(20)Plug - Lubrication SystemTightening to 2,5 m.daN
(21)Bolts - Crankshaft Main Bearing Cap CastingTightening to 2 m.daN
(21)Bolts - Crankshaft Main Bearing Cap CastingAngular tighten to 49 ± 2 °
(22)Bolts - Coolant Inlet ManifoldTightening to 0,8 m.daN
This is the conversion:
Newton metre (N•m)20
deca Newton metre (daN•m)2
kilo Newton metre (kN•m)0.02
deci Newton metre (dN•m)200
centi Newton metre (cN•m)2000
milli Newton metre (mN•m)20000
micro Newton metre (?N•m)2 E+7
Newton millimetre (N•mm)20000
jsp
x 12
I torqued it 20nm , still it leaks
x 6955
If you have taken the water pump off, you MUST replace the O Ring with a new seal or it will leak in case you haven't done so, as these are not designed to be reused, as they deform and will never seal properly if refitted.
jsp
x 12
yes it has been replaced, I guess dayco aftermarket doesnt seal well?
x 6955
Several factors here - is it the exact correct part number and the quality of the aftermarket parts can be very hit and miss.
jsp
x 12
I torqued to 30Nm and its not leaking anymore
