disable aircon - 2002 xsara picasso 1.6 engine
griffo
Unread post by griffo »
hi all.
is there a way to disable the air con on a 2002 xsara picasso (1.6 engine)?
personally i dont like air con and no mater what i do, it switches on when i start my car.
the screen is hard to view, i guess due to age so it's almost impossible to see what it is doing!
so, any idea how i permanently disable it? a certain fuse maybe?
thanks!
x 3299
Re: disable aircon - 2002 xsara picasso 1.6 engine
On the control panel there may be a button marked 'Eco'. If there is, pressing it will turn off the a/c.
x 1438
Unread post by xantia_v6 »
You could also unplug either the compressor clutch or the A/C pressure sensor under the bonnet. The latter is probably easier to reach.
griffo
thanks for the replies. much appreciated.
g.
griffo
hello again! can anyone tell me where the aircon pressure switch is located under the bonnet?
i would 'RTFM' but i dont have one, cannot get one in spain and i have had no joy online.
all help appreciated!
g.
