Very strange bolt!!
x 3302
Re: Very strange bolt!!
x 1066
Unread post by Rp0thejester »
Wince!!! That's an understatement! My bum was twitching like a rabbits nose!!
x 3302
The first one matches the part number supplied by Marc.
x 1056
Unread post by wheeler »
Looks like the swirl control actuator to me, The plastic bit on the rods were known to break & i heard the parts werent available anymore. its possibly been plugged to stop the rod moving about?
x 1066
What's a swirl control actuator?
x 5670
Rp0thejester wrote: 13 Jun 2023, 21:35 What's a swirl control actuator?
Similar to a Turbo Encabulator.
x 1066
I have to ask....are you taking the p1ss? Is there an English version??
x 3302
Their purpose is to ensure that the air entering the cylinder is sufficiently turbulent for good fuel-air mixing even at low engine speeds. This aids in reducing emissions and may also improve low-end torque.
x 1066
I preferred Myglarens explanation. Purely because at work I can get someone to translate yours James
x 3302
Think of the swirl system as a cup of tea. If you just add the milk and sugar and then drink it the mixture will be inconsistent. Stirring the contents of the cup then blends the tea, milk and sugar together to (hopefully) make a nice cuppa.
x 5670
Rp0thejester wrote: 13 Jun 2023, 21:42 I have to ask....are you taking the p1ss? Is there an English version??
It's complete bollocks in the Stanley Unwin tradition.
x 1066
I know, just playing along, I'm not that green, got to find the funnys in life
x 1056
Yep, definitely the swirl valve actuator. And yes its no longer available.
x 1066
wheeler wrote: 13 Jun 2023, 22:07 Yep, definitely the swirl valve actuator. And yes its no longer available.
so what does it do??
x 1056
It opens & closes the little butterfly's (6) which make the air go in to the cylinders differently by creating swirl & makes the air/fuel mix better. I would guess that someone has jammed it fully open or fully closed somehow.
