C5 X7 - removing navigation screen
x 1931
...or at least removing the fascia surrounding it.
The screen seems to have a gap between it and the fascia surrounding it and I don't think it should have. Instructions for getting at it please?
x 6955
Re: C5 X7 - removing navigation screen
You take the lower trim strip off Paul with trim removal tools, then this will expose 3 bolts as above.
Unclip: The fascia panel front panel (2) ( as "b", "c") using trim removal tools. You should be able to pull it away horizontally towards you on those clips as they snap in and out.
Detach: The fascia panel front panel (2).
That should give you access to the MFS.
x 1931
Ta. Tomorrow's little job.
