C8 Fuse
- x 1083
C8 Fuse
This is probably gunna end up in the joke section, but what 5amp fuse does my beloved C8 need to operate the main screen washer jets, I've tried many but definitely wrong, thanks in advance
Reason: Moved to Citroen Forum
Champion of Where's CitroJim
- x 6947
Re: C8 Fuse
Fuse F3 (10 Amp) in the engine Fuse Box.
- x 2364
Re: C8 Fuse
In my long search for someone who actually sold fuses
viewtopic.php?t=73289
I discovered there are at least three types of blade type fuses: the normal ones, "mini" and "micro"
Actually, a fourth type is the large "maxi" fuses, big current rating for those.
My C7 has some normal and some mini fuses and maxi ones under the bonnet (e.g suspension pump)
I've yet to see any of the Micro ones yet. Think your C8 is similar vintage so would guess mini is likely what you need?
Oh, and I also found some very odd three legged "two fuses in one" things too!
Stick a picture up and I think I could tell you what type visually
- x 2364
Re: C8 Fuse
I think that is "where and what rating?" but I took the question to be "what type?"
- x 6947
Re: C8 Fuse
No worries, I'm so used to just advising where and what Matt, but if it's the type then there are 2 types used on this fusebox on this C8; the larger 40 Amp larger fuse, part: 6500GJ and the mini Fuse in this case for the 10A F3 is part: 6500N9
- x 1083
Re: C8 Fuse
It's a 5 amp fuse, micro in size but really long pins on it!!!! Just can't find anywhere
- x 2364
Re: C8 Fuse
Picture please, I'm intrigued!Rp0thejester wrote: 21 May 2023, 17:40 It's a 5 amp fuse, micro in size but really long pins on it!!!! Just can't find anywhere
- x 1083
Re: C8 Fuse
I binned it, I'll pull another as an example
- x 1083
Re: C8 Fuse
- Spoiler: show
- x 3298
Re: C8 Fuse
I have a fair few of the ones on the left. I haven't seen the one on the right before.
- x 8148
Re: C8 Fuse
Me too, I have most types but the ones you need can be found here:
https://www.ebay.co.uk/itm/133573507986 ... R6yynfSHYg
- x 1083
Re: C8 Fuse
So Micro 2, thanks guys much appreciated
- x 1056
Re: C8 Fuse
The ones on the right can be found in some Honda's, Hyundais' & Kia's
You can also get mini fuses like the one on the left but with longer legs
- x 5675
Re: C8 Fuse
I'll have to have a dig in my Honda fusebox and see. Never had the need so far.
There! Jinxed it.
There! Jinxed it.
- x 1056
Re: C8 Fuse
You can normally still fit a standard mini fuse in place of the stubby leg ones as the leg spacing is the same, They just stick out a bit.
