DV6DTED Engine.
Huskyxantia
x 927
Re: DV6DTED Engine.
Unread post by Huskyxantia »
Id use locktite then do as manual says.
:-D
x 6947
Re: DV6DTED Engine.
Let's keep it specific to the exact engine as the torques differ.
The following is for the DV6DTED (Euro 5) engine as per the VIN you specified:
RefDesignationStageTightening Torque
(1)Connections (Diesel injector )Pre-tighten2 daNm
(1)Connections (Diesel injector )Tightening2,5 daNm
(2)Connections (Fuel high pressure pipes / Fuel high pressure common injection rail )Pre-tighten2 daNm
(2)Connections (Fuel high pressure pipes / Fuel high pressure common injection rail )Tightening2,5 daNm
(3)Union (High-pressure fuel pipe / Fuel high pressure pump)Pre-tighten2 daNm
(3)Union (High-pressure fuel pipe / Fuel high pressure pump)Tightening2,5 daNm
(4)Bolts (Fuel high pressure pump rear bracket)Tightening1 daNm
(5)Bolts (Fuel high pressure pump rear bracket)Tightening1 daNm
(6)Bolts (Diesel injector fixing flange)Pre-tighten0,7 daNm
(6)Bolts (Diesel injector fixing flange)Angular Tightening80°
(7)Bolts (Fuel high pressure pump front bracket)Tightening2 daNm
(8)Bolts (Fuel injection pump / Bracket )Tightening2 daNm
(9)Fuel injection pump pulley nutTightening5 daNm
(10)Bolts (Fuel high pressure pump rear bracket)Tightening2 daNm
(11)Bolts (Fuel high pressure common injection rail / Engine block)Tightening2 daNm
(12)Fuel high pressure sensorTightening4,5 daNm
aircool
Re: DV6DTED Engine.
Unread post by aircool »
Also looking to move on from 306 life, I have been looking at DV6 powered cars and seem to be settling on a T9 308. Trying to avoid the 16V for simplicity and reliability to see that the DV6DTED is a 16v unit but when on catcarinfo or similar it seems to be an 8v?
Are the Euro 5 engines all 8 valve ?
x 6947
Re: DV6DTED Engine.
Some of the 1.6 Diesels were originally 16 valve, but were changed back to 8 valve, so depends on the engine code as to which one is which:
DV6 ATED490 PS (66 kW; 89 hp)Turbo-Diesel 16-valve
DV6 B75 PS (55 kW; 74 hp)Turbo-Diesel 16-valve
DV6 TED4110 PS (81 kW; 108 hp)Turbo-Diesel 16-valve
DV6 C115 PS (85 kW; 113 hp)Turbo-Diesel 8-valve
DV6 D92 PS (68 kW; 91 hp)Turbo-Diesel 8-valve
DV6 FE75 PS (55 kW; 74 hp)Turbo-Diesel 8-valve
DV6 FD95 PS (70 kW; 94 hp)[4]Turbo-Diesel 8-valve
DV6 FC120 PS (88 kW; 118 hp)[4]Turbo-Diesel 8-valve
Mark1967
Re: DV6DTED Engine.
Unread post by Mark1967 »
I need an engine for my Peugeot partner tepee hdi 92. Reg wk13xga but not sure exactly what the engine code is?
x 6947
Re: DV6DTED Engine.
Pop your VIN up and I can advise of the engine code. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
If you require the actual official part number for a new or replacement engine, that will require a membership upgrade as this info is chargeable (see details below):
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years (pending continued service availability), so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
GO_207
Re: DV6DTED Engine.
Unread post by GO_207 »
Can you please plans / pictures about to replace the EGR valve DV6 D engine on Peugeot 207 1.6 hdi year 2010?
GO_207
Re: DV6DTED Engine.
...and for egr cooler please
