Stickyfinger's XM bodywork fixes.
x 1996
Unread post by Stickyfinger »
Work starts to replace\: Front bumper, two rh doors, rear rh wing, rear bumper....all thanks to Bamby and his four friends!
The only positive part of this will be that I do not have to fight with rusted parts or bolts.
x 8397
Re: Sticyfingers XM bodywork fixes.
Good to see the XM finally getting all the attention it so richly deserves Alasdair :D
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
Is there a reason your name is misspelt in the title?
x 1996
Armidillo wrote: 06 May 2023, 06:55 Is there a reason your name is misspelt in the title?
Yes, because I am a pratt
Armidillo
(Donor 2022)
x 274
Re: Stickyfinger's XM bodywork fixes.
That's much better - lucky you can edit thread titles :).
DHallworth
x 167
Unread post by DHallworth »
Looking forward to more pictures as you progress.
Bodywork is something I've never been brave enough to try!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1996
DHallworth wrote: 09 May 2023, 23:25 Looking forward to more pictures as you progress.
David.
Nor me.....so this will be a "journey" of self development :)
x 1996
Fixed the back panel, wing next....red outlines the damaged areas
x 8397
Excellent :D Good to see work on the XM :D
x 1996
No going back now, first cuts to allow access, some (pre final cut) correction to the door slam outer pressing from the inside and to check just how rust free the car is. IF it was not as spectacularly free of rust then I would have broken the car.....but this XM is quite a survivor and is in a magnificent (God knows how) condition in all the well known areas of corrosion.
I hope my skills are up to the job !
x 8123
Stickyfinger wrote: 14 Jun 2023, 13:31
No question there Alasdair!, the intriguing question is: Will the job warrant your skills? :-D
x 1996
Hahjahha, you have more faith than me :)
x 8397
Excellent :D Keep up the good work Alasdair ;)
x 3565
A couple of these full of body filler and you'll be golden :-D
GH-SA
GH SA, CC BY-SA 4.0 <https://creativecommons.org/licenses/by-sa/4.0>, via Wikimedia Commons
x 1996
Getting there.....bang bang, ouch/bugger, bang bang bang...........
