The starter handle
x 8137
The starting handle was one area where the manufacturers never saw the potential for starting handles as fashionable accessories: :-D
BFTW
BFTW
x 5672
I did use the starting handle on my GS, just to try it, never actually needed.
x 1240
Unread post by Peter.N. »
mickthemaverick wrote: 30 Apr 2023, 11:18 The starting handle was one area where the manufacturers never saw the potential for starting handles as fashionable accessories: :-D
That looks like one for a Petter/Lister diesel. We had a diesel Austin A60, that had a starting handle, I don't know why only Popeye could have started it using one.
x 8137
Peter.N. wrote: 30 Apr 2023, 16:30
That looks like one for a Petter/Lister diesel. We had a diesel Austin A60, that had a starting handle, I don't know why you could never have started only Popeye could have started it using it.
Did the car not come with a tin of spinach in the glovebox Peter? :-D
x 1240
Not that I noticed Mick, but it was secondhand so someone might have nicked it.
x 8417
I have great memories of hand-starting many Lister diesels using a similar, but not so brightly painted, handle as that.
The most important thing was never to let go of it when the engine started ;) Keep it well held or disaster could (would) strike... If you let go of it then run and hide - fast!
When the engine was up and running, just slide it off the shaft whilst still holding it firmly...
I've hand-started some very large military gensets and using the decompressors, not as hard a task as it might be first thought...
x 1240
I have one on a Lister generator Jim.
Bird Brands
The Wren and the Kiwi...big in shoe polish
Mentioned the Wren over on POTD, but that has led onto the Kiwi. As you look around at the footwear of the masses in the 2020's, it isn't the type of thing that requires a daily brushing, blackening and polishing with a tin of shoe polish.
bird brands
bird brands
x 8137
Must include this one too:
BFTW
BFTW
x 5672
Kiwi no longer in production.
Sure I have some here somewhere. None used in ages.
x 8137
I had a feeling I had a tin of Dubbin in an old box in the garage, so I went to see. Alas no Dubbin, however I did come across this motley selection of polishes and treatments from days gone by which includes one tin from Neil's original picture, the Kiwi Parade Gloss Prestige!! :-D
My motley selection. Click on to enlarge!
x 5672
I knew there was some somewhere, 6' from where I was sat.
Presume the wife bought it so it has probably been here 25 years or more.
x 1240
How about 'Black Lead' for the range, anyone got any?
x 8137
Nearest I have to that Peter is black lead flashing paint!! :-D
