Hi everyone,
I have driven my 2001 Citroen C15 from the south of Spain to the UK and the input bearing on the gearbox is noisy.
I would like to replace the gearbox before I travel back but am having some difficulty's finding a matching replacement.
Is there any difference between a gearbox on the 1.9D and other Citroen C15s?
My Vin is VF7**************[VIN obfuscated, can be read by forum staff] registered 30th Oct 2001 in Spain.
The Vin on some ebay listings for gearboxes is: VF7**************[VIN obfuscated, can be read by forum staff] VF7**************[VIN obfuscated, can be read by forum staff] VF7**************[VIN obfuscated, can be read by forum staff]
Would any of these gearboxes fit or does it have to be specific?
Any help much appreciated!
p.s this is my first french car and I really like it!
C15 gearbox help
jaycey001
Re: C15 gearbox help
It seems my gearbox is an obscure fitment in the Uk - Any help really appreciated - I have found these codes on my gearbox but they seem to match to a Peugeot?
I think that box is fitted to a variety of PSA vehicles with the 1.9 engine, BXs 205s and 306s come to mind, the problem may be finding one with the appropriate ratios.
- x 6950
Unfortunately there is very little data on this, as some older vehicles like the C15 have very little electronic data available given the age.
jaycey001
On my gearbox I have this tag code 3727025A is there any reason a different tag code from a C15 wouldn't fit and work okay?GiveMeABreak wrote: 26 Apr 2023, 22:36 Unfortunately there is very little data on this, as some older vehicles like the C15 have very little electronic data available given the age.
It's the 20TE11 gearbox
- x 6950
Sound advice would be that you match up the codes from your existing gearbox to a donor.
Or repair your own box, not too difficult if it's only bearing noise, bearings are cheap enough if you shop around the specialists.GiveMeABreak wrote: 27 Apr 2023, 08:54 Sound advice would be that you match up the codes from your existing gearbox to a donor.
