dpf
dandyman1
dpf
Unread post by dandyman1 »
can anyone tell me if my citroen dispatch 2.0l hdi 120 year 2007 has a dpf and Eolys fluid tank?
Thanks.
last vin numbers are 640*****
x 6950
Re: dpf
Hi, you don't have a Diesel Particle Filter and therefore no Additive tank either.
dandyman1
Re: dpf
Thanks Marc for your reply.
How did you come to this answer? Its just after more research and looking i saw on line what looked like an Eolys tank hidden away with the fuel tank and also the snapon type line that i have seen in various vids that has the green pinch tabs release, usually associated with the Eolys tank situated what looks like on my diesel tank?
I am confused.
x 6950
Re: dpf
The information is based on the VIS number you provided via Citroen's data. There are many engines fitted to this model and in your case it is the one without the Diesel Particulate Filter - which is why we usually ask for the VIN so we know exactly what you have and not what someone else may have that is a different but similar engine on the internet.
According to the VIS, you have a:
DISPATCH III SHORT PANEL VAN H1 TYPE 12 2.0 HDi 120 (DW10UTED4) with Manual gearbox 6 speed
However You will need to provide the complete VIN so I can double check and confirm the exact engine type.
dandyman1
Re: dpf
thanks it is VF7**************[VIN obfuscated, can be read by forum staff]***************
x 6950
Re: dpf
Ok, confirmed - as I said before - no particle filter / additive system - diagram of your tank below:
dandyman1
Re: dpf
Good man Marc.
Thank you so much. I am glad i don't have one.. maybe one less thing to worry about! I am not sure that system is very good after reding up!! they seem to use more fuel?? cant be less polluting i think.. and costly to maintain.
Thanks again.
x 6950
Re: dpf
They are better for the environment and our health as they catch and trap over 99% of the small particulate matter that can cause blockages and development of the lungs of small children. The particulates don't do much good for the rest of us either - so they do their job well. Most, if not all Diesel vehicles now have them, along with the new SCR (Selective Catalytic Reduction) systems to also convert the NOx pollutants using Ammonia (Urea or Cow Pee) into Water and Nitrogen.
But on your car, none of these to worry about!
dandyman1
Re: dpf
thanks for your time Marc
You dont know who i can turn to for some help with my power steering fault do you? Its a head banger!!
x 6950
Re: dpf
I was going to suggest you start a new topic for that - but see you have now :-D
cableguy16
Re: dpf
Unread post by cableguy16 »
Hi Guys i have a 2010 Scudo 140 2.0JTD (HDI) which is the same i have been told as the 136 dispatch! it had Eolys and i had it removed when new due to issues but i now need to refit and flash the ECU! has anyone got the workshop manual diagrams for the DPF as i have the DPF the Tanks but seem to be missing some extra pipes!
x 6950
Re: dpf
We only deal with PSA badged vehicles as there were different different options and engines fitted, so I would not be able to provide the details for your vehicle as it is FIAT badged and the VIN would not provide anything.
cableguy16
Re: dpf
i can't find anything on the fiat group they sent me here as the van was made in a PSA factory i have the DPF and the Eolys tank i just need the citroen diagram of the pipe locations all the DPF parts have the citroen logo on it!
x 6950
Re: dpf
Ok, I understand that, but to be accurate we require the VIN to get the exact parts for the exact vehicle. Without this we will be guessing as there were 2.0 HDi 120 & 2.0 HDi 136 engines for this year.
cableguy16
Re: dpf
It’s the 136 engine L2H1
