ASK or FSK
cncjeff1
ASK or FSK
Unread post by cncjeff1 »
I have a 2016 Citroen Berlingo Multispace VIN VF7**************[VIN obfuscated, can be read by forum staff]. The original remote is marked CE0523. How can I determine if it is ASK or FSK? The problem is that it works for a few days, then the battery dies and it will not open or lock the doors. It will however always start the car. If I know if it is ASK or FSK, then I can get a new remote. Thank You in advance for yourhelp.
x 1939
Re: ASK or FSK
The key for my 2013 C5 X7 is the same style and also marked CE0253. I know that this is ASK as the duplicate key I coded to the car is ASK.
x 6945
Re: ASK or FSK
A couple of things.
Here are the part numbers for the official key / fob for your vehicle:
Item (1)
Key Uncut, part: 6490FS.
Key Cut, part: 6490FT.
(note you don't have the type shown under item (2).
Second, you vehicle is being flagged up with an outstanding after sales campaign. I would ring the dealer, quote the VIN and they will be able to advise what the work entails, but it will be free of charge.
x 1055
Re: ASK or FSK
Unread post by wheeler »
Paul-R wrote: 04 Apr 2023, 12:14 The key for my 2013 C5 X7 is the same style and also marked CE0253. I know that this is ASK as the duplicate key I coded to the car is ASK.
A CE0253 can come in both ASK and FSK variants.
Going on the data i have i believe this will be FSK.
Sloppysod
x 396
Re: ASK or FSK
Unread post by Sloppysod »
🙋Please, What do these two acronyms mean? What's the difference??
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6945
Re: ASK or FSK
It's all to do with the frequency modulation Stu Amplitude Shift Keying and Frequency Shift Keying.
x 1055
Re: ASK or FSK
Its kind of like the difference between AM radio & FM radio
Sloppysod
x 396
Re: ASK or FSK
Thanks guys, it's just to know. 👍
I learnt to say good-bye before ttfn (and ttfn does not make sense anyway!😏)
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 1939
Re: ASK or FSK
ttfn = ta-ta for now. Was popularised by Jimmy Young on his Radio 2 radio show I think.
cncjeff1
Re: ASK or FSK
Thanks everyone for the replies. So far, there is one vote for ASK and one vote for FSK. Can anyone tell from the VIN?
x 6945
Re: ASK or FSK
The VIN won't tell you this sort of info, but I've provided the replacement fob part numbers for you.
All you have to do is search on those numbers to find suppliers that can offer a replacement, without needing to go into the specifics.
x 1055
Re: ASK or FSK
As i said going on my own notes & data i believe this to be FSK. Considering the price of aftermarket remotes are a fraction of the cost of the originals, you could just buy both types, If you select the wrong one the transponder should still program anyway, just the remote part wont work so will still be good as a spare, worst case you have a replacement key shell (the rubber buttons perish over time).
I personally use universal keys where possible, There very few (namely VAN/CAN C2, C3 & Xsara Picasso) Citroen or Peugeot models that can't be generated using them. If you select the wrong type & it dosent work you just re flash it & try a different frequency type. In my opinion the quality of these are way superior than the genuine originals yet are a fraction of the price & you can gat many different styles.
The one below is a DS style universal currently used on my car.
x 1939
Re: ASK or FSK
I'm interested in knowing more about these universal keys Wheeler. Are they just for bladeless type fobs? Where can I find more information?
x 5673
Re: ASK or FSK
wheeler wrote: 05 Apr 2023, 09:56
That is what I have for my Civic :)
Annoying when I inadvertently press the middle button, it does nothing.
x 1055
Re: ASK or FSK
Paul-R wrote: 05 Apr 2023, 10:38 I'm interested in knowing more about these universal keys Wheeler. Are they just for bladeless type fobs? Where can I find more information?
No, that's a bladed type flip key above, the blade is just folded in. The blade fittings are all the same so you can fit a Ford, Vauxhall, VW or whatever you want type blade. There are proximity/keyless versions too. In fact the keyles versions you can get a watch that becomes the universal key. The main ones are made by Xhorse, KD & Autel.
They dont work with every car out there but i reckon they can be used on around 80% of the cars out there just now.
myglaren wrote: 05 Apr 2023, 10:49
You can get that style in the 2 or 3 button variants, the one in my pic is actually only a 2 button version so the bit in the middle isn't actually a button. Some people only stock the 3 button versions as they can also be used on 2 button cars, sometimes depending on the car the 3rd button actually does something when you program it to a car that was originally 2 button.
