2015 DS3 1.2 not turning. Fault code 0528.(starter does not turn crank)
malawiboy1
Locked user account
Unread post by malawiboy1 »
hi
Can someone help me with this fault code 0528.(starter does not turn crank) with key
But if I bypass the starter relay, the car fires up, I have bought a new relay, but not
have much no have much luck any one can someone help with wire ring diagram or any ideas please
this are the fault codes
1.0528 Fault: Absence Of Command Of The Starter
2.0567 Service Battery Voltage Fault
3.0006 Fault In The Transmission Of The Main Triggering Status On The I/S (Intersystems) CAN
4.0012 Fault Built-in Systems Interface Mute On Intersystems CAN
5.0015 Fault: No Communication With Engine ECU
6.0047 Fault Absence Of Communication With The Electric Power Steering ECU
Thanks in advance for your time. :?
x 6961
Re: 2015 DS3 1.2 not turning. Fault code 0528.(starter does not turn crank)
Those are not valid fault codes, sorry. They should begin with 'P' or 'U' for example.
malawiboy1
Locked user account
here is the same code from pp2000 diagbox code 9528 - 'Absence of command of the starter
x 6961
You have not updated your profile on the left, so I was using your C4 Picasso 2015, not a DS3 petrol!
You'll need to provide the VIN for this new vehicle and please update your profile. I'll then take another look, although they are still missing the letter from the code, but I'm not hopeful I'll have anything for this vehicle.
malawiboy1
Locked user account
VIN VF7**************[VIN obfuscated, can be read by forum staff]
malawiboy1
Locked user account
malawiboy1 wrote: 02 Apr 2023, 13:57
GiveMeABreak wrote: 02 Apr 2023, 11:28 You have not updated your profile on the left, so I was using your C4 Picasso 2015, not a DS3 petrol!
VIN:VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
forgot to mention before this scan I had this fault code : {09A0 starter control relay fault } i replaced the starter relay but not luck
but if i Bridge the wire from the starter relay the car fires up
x 6961
Sorry, can't help you the codes are missing half the info. They should be something like this: P0122 11
malawiboy1
Locked user account
GiveMeABreak wrote: 02 Apr 2023, 15:52 Sorry, can't help you the codes are missing half the info. They should be something like this: P0122 11
here is a copy of the scan
x 6961
As you can see these are completely different from what you posted in your first post!
How old is the battery? Have you tried putting a new battery on first of all?
If that doesn't reduce the errors, you'll need a good auto electrician to look at it as you have comms issues with all the major ECUs on the vehicle.
Fault Code: 9528
Description of Fault: Absence of command of the starter: Coherence. The drop in voltage linked to the activation of the starter motor does not occur (If the drop in voltage is more than 1,5 V).
Conditions of activation of the diagnostics
At least one of the following conditions must be fulfilled:
- Key in starting position (Seen by the BSI and for a set duration)
- Automatic gearbox in park or neutral position
- Foot on the brake pedal and gear lever on Neutral ( piloted gearbox)
Conditions for Fault to clear: At least one of the following conditions must be fulfilled:
- The drop in voltage linked to the activation of the starter motor is more than 1,5 V
- The key is in a position other than starter+ (+DEM)
Downgrade Modes whilst Fault is active: -
Symptoms:
  • Starting problem
Suspect Areas:
  • Starter
  • Control of the energising of the starter
  • Engine ECU
  • Engine fuse box
  • Electrical harness: Controlled manual gearbox ECU starting authorisation / automatic gearbox (According to equipment)
  • Automatic gearbox / Piloted manual gearbox (According to equipment)
  • Electrical harness: Engine ECU starting authorisation
  • Electrical harness: Starter positive signal from the ignition switch to the engine fusebox
F522 Fault: Saturation of the log of faults (Too many fault events recorded at the same time: These events temporarily ignored): Not characterised
Fault Code: F567
Description of Fault: Voltage generator fault.
Description of the diagnostics:
Possibility 1
The vehicle has done less than 20 kilometres and the battery charge status is under 50%.
Possibility 2
No communication on the network LIN (Between the BSI and the battery charge status control unit).
Conditions of activation of the diagnostics:
Ignition on
Conditions for Fault to clear: Possibility 1
The battery charge status is over 50%.
Possibility 2
Communication on the LIN network is active (Between the BSI and the battery charge status control unit).
Symptoms:
  • Lighting of battery warning lamp
Suspect Areas:
  • Configuration of the battery charge status control unit
  • Battery
F006: Fault in the transmission of the main triggering status on the CAN I/S (Inter-system): Not characterised
F012: Fault with BSI not communicating on the CAN I/S (Inter-system): Not characterised
Fault Code: F015
Description of Fault: No communication with the engine management ECU fault : Not characterised. No reception of data coming from the engine management ECU through the BSI over the CAN Intersystems (For 1 s).
Conditions for Fault to clear: Reception of data coming from the engine management ECU through the BSI over the CAN Instersystem network (For 1 s).
Symptoms:
  • Starting impossible
Suspect Areas:
  • Remote-controlled wake-up line
  • Main supply
  • Weights
  • Intersystems CAN
  • ABS or ESP
  • Engine fuse box
  • Engine ECU
  • Built-in systems interface
Fault Code: 9528
Symptoms:
  • Starting problem
Suspect Areas:
  • Starter
  • Engine ECU
  • Engine fuse box
  • automatic gearbox / Piloted manual gearbox (According to equipment)
7173: Oil temperature sensor information fault: Not characterised
