C4 Picasso heating climate problems
shaun1983m
Unread post by shaun1983m »
Hi all I’m after some help with my 2008 c4 Picasso exclusive for the last few weeks the climate control panel has been flickering on and off which results in heaters going on and off now it’s gone off altogether drivers side and passenger side not even illuminated so now I have got to have the windows open in this weather so the screen doesn’t mist up any help in what it could be would be much appreciated
x 6948
Re: C4 Picasso heating climate problems
Try a BSI Reset / Battery Disconnect / Reconnect Procedure first as that can eliminate any BSI issues.
If that has not solved it, then ideally a diagnostic with Lexia / Diagbox would be recommended to determine the fault. I could just say the A/C ECU, but it really needs a diagnostic first.
shaun1983m
Thanks will give it ago tomorrow. Also Could you tell me where the climate ecu is located please
x 6948
Best to pop your VIN up (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) as there are multiple variations to these depending on trim level and model / options.
shaun1983m
Thanks VIN: VF7**************[VIN obfuscated, can be read by forum staff]
x 6948
As there are both driver and passenger controls at each end of the dash for controlling the system and you have said that both displays are fading, it would lead me to suggest the AC ECU as both these units plug into the AC ECU. What about the rear passenger control units? Are these displays also fading?
I would suggest that you get the AC ECU diagnosed as faulty to confirm this.
The ECU itself is on the right side of the fascia, shown here as item (3):
All the control panels front and rear feed into this ECU
shaun1983m
Thanks the front panels don’t light up at all and the rear ones haven’t got screens just a knob which doesn’t work now.
shaun1983m
Second hand ecu is only cheap on eBay if I get one the same part number to try is it just plug and play or does it need to be programmed in
x 6948
There are various part numbers for this unit, so ensure you have an identical part number. Whether it will need any configuration I can't say from here of course, but there is nothing to suggest that it does from the info I have.
shaun1983m
Thank you very much for your help your a legend I will update if it works 🤞🏻
shaun1983m
Just an update thanks for your help bought a second hand ecu off eBay £12 bargain replaced the old one it is a bit fiddly but 10 mins later all working fine thank you 🙏
x 6948
Great news, well done and thanks for the update.
