Xantia Headlights
splat
Xantia Headlights
Does anyone know whether a headlamp from a post-facelift Xantia will fit a pre-facelift '97?
Ross_K
- x 110
- x 8070
On the subject of headlights. Since owning my Xantia, Saturday night was the first time I'd driven it in proper darkness! Main beam is brilliant but on dip the light output, whilst adequate, seemed well down. A bit like switching between halogen and the old tungsten bulbs of long ago. Is this normal? Beam pattern is excellent though.
jeremy
Worth having a look at all the connections. Is the dim-dip working correctly?
Sidelights should work normally, put them on and look for small bulb only, then put ignition on - should be brighter with limited output from dip filament, then put on dipped headlights - same filament should glow at full brightness.
Jeremy
Jeremy
- x 8070
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
Jeremy
Good point Jeremy, Mine does not appear to have dim-dip. Is that right for a 1993 RP6086 model?
Jeremy
nick
jeremy
nick
nick
To go back to the original post, no, a post '98 headlight definitely won't fit a pre-facelift car.
It is possible to get brighter bulbs, I've fitted Philips VisionPlus in my dipped beam and they're a huge improvement on the standard bulbs. No higher wattage, just more efficient at giving out light.
Osram Silver Star are supposed to be slightly better still, have a look at;
http://www.powerbulbs.co.uk/
